While I keep working on new versions of my Domoticz plugin, I realized there is one outstanding very minor issue that I am faced with in my openLuup logs…
when calling a registered http handler function in my plugin from a client system/application through a “curl” or “wget”, I keep getting tcp closed errors logged by the openLuup server
2016-12-09 18:52:19.490 openLuup.server:: new client connection from 127.0.0.1: tcp{client}: 0x1aff180
2016-12-09 18:52:19.490 openLuup.server:: GET /data_request?id=lr_DZUpdate&idx=48 HTTP/1.1 tcp{client}: 0x1aff180
[request is processed by my registered handler]
2016-12-09 18:52:19.497 openLuup.server:: request completed (42 bytes, 1 chunks, 6 ms) tcp{client}: 0x1aff180
2016-12-09 18:52:19.497 openLuup.server:: receive error: closed tcp{client}: 0x1aff180
while calling the same url from Chrome or from a lua http function yields no error from the openLuup server
2016-12-09 18:58:54.035 openLuup.server:: new client connection from 192.168.0.32: tcp{client}: 0x19ce408
2016-12-09 18:58:54.139 openLuup.server:: GET /data_request?id=lr_DZUpdate&idx=48 HTTP/1.1 tcp{client}: 0x19ce408
2016-12-09 18:58:54.152 openLuup.server:: request completed (42 bytes, 1 chunks, 12 ms) tcp{client}: 0x19ce408
[other stuff not relevant happens]
2016-12-09 18:51:17.533 openLuup.server:: closing client connection: tcp{client}: 0x19ce408
I am not proficient at all in network issues, but I suspect the errors probably stem that when a curl or wget process ends its kills the relevant connection, while the openLuup server is designed to end these by itself… If I am right in my analysis, is there a specific reason for that ?
My http calls are properly handled so it does not matter too much, if it were not for the optics of seeing all these errors in my logs…
