This is my 2000th post, so I wanted to make it significant to me, if to nobody else!
I’m aware that this can be a pivotal time for some developers (three years ago @Ap15e made his 2000th post his last: My final post) and it’s sadly no surprise to note the issues which drove him away:
- “My personal ROI from MCV is just too low”
- “resources visible to me are just too limited to create a sufficiently stable and bug free and documented product”
- “There is no offical documentation for developers, and when MCV does document items, there is no guarantee that MiOS works as documented”
- “Installing UI5 on my Vera V2 left the device in a totally unusable state: severe slowdowns, several lockups per week requiring a hard reboot, several soft reboots per day.”
- New state of my plugins/scripts: EOL, unsupported."
Nowadays, read ‘UI7’ and ‘Vera3/Lite’. We’ve seen others remove their apps from the forum too. The direction of developer drift now seems to be OpenHAB… but I’m loathe to abandon my investment in MiOS, and Lua, so I agree with this comment:
So what to do? I’m not going to pull my apps from the public domain (EventWatcher, Netatmo, DataYours) in fact I want to continue to develop and support them. But I want to work in a more open and stable environment. I note the following:
- Vera is a great Z-wave to HTTP bridge
- The plugins developed here on the forum are great
- The Luup API and HTTP Requests are great
- Scenes, in particular the definition of triggers are abysmal
- Lua is the best language in the world (OK, forgive me)
All would be solved if Luup was open source and could be run on the plethora of cheap and reliable hardware available today. But it’s not. But we could get something like that effect if we engineered a sufficient subset of Luup to run on such a platform. Could it be done? What would we need?
- UI
- scheduler
- web server
- Luup compatible API
- Device and Implementation xml file reader
- Zwave bridge to Vera
- runs most plugins without modification
What we wouldn’t need is UPnP.
What have we (nearly) got already?
- We have, courtesy of @amg0, the most excellent altUI: Alternate UI to UI7, and that, I think, is probably the hardest one to do in the above list.
- Items 2 - 5, and 7, I’ve prototyped, in pure Lua, and posted elsewhere: DataYours on Raspberry Pi, running selected plugins unmodified, including: DataYours, EventWatcher, Netatmo, RBLuaTest, altUI. See screenshot attached.
Is it worth the effort? Probably not. Will I pursue this quest? Yes, because as @Aaron noted in @Ap15’s final thread:
I plan to post the code on GitHub in due course: and now it is here GitHub - akbooer/openLuup: a pure-Lua open-source emulation of the Vera Luup environment
October 2015: A summary of the project status…
openLuup is an environment which supports the running of some MiOS (Vera) plugins on generic Unix systems (or, indeed, Windows systems.) Processors such as Raspberry Pi and BeagleBone Black are ideal for running this environment, although it can also run on Apple Mac, Microsoft Windows PCs, anything, in fact, which can run Lua code (most things can - even an Arduino Yun board.) The intention is to offload processing (cpu and memory use) from a running Vera to a remote machine to increase system reliability.
Running on non-specific hardware means that there is no native support for Z-wave, although plugins to handle Z-wave USB sticks may support this. The full range of MySensors (http://www.mysensors.org/) Arduino devices are supported though the Ethernet Bridge plugin available on that site. A plugin to provide a bi-directional ‘bridge’ (monitoring / control) to remote MiOS (Vera) systems is provided in the openLuup installation.
openLuup is extremely fast to start (a few seconds before it starts running any created devices startup code) has very low cpu load, and has a very compact memory footprint. Whereas each plugin on a Vera system might take ~4 Mbytes, it’s far less than this under openLuup, in fact, the whole system can fit into that sort of space. Since the hardware on which it runs is anyway likely to have much more physical memory than current Vera systems, memory is not really an issue.
There is no built-in user interface, but we have, courtesy of @amg0, the most excellent altUI: Alternate UI to UI7 (see the Vera forum board http://forum.micasaverde.com/index.php/board,78.0.html) An automated way of installing and updating the ALTUI environment is now built-in to openLuup. There’s actually no requirement for any user interface if all that’s needed is an environment to run plugins.
Devices, scenes, rooms and attributes are persisted across restarts. The startup initialisation process supports both the option of starting with a ‘factory-reset’ system, or any saved image, or continuing seamlessly with the previously saved environment. A separate utility is provided to transfer a complete set of uncompressed device files and icons from any Vera on your network to the openLuup target machine.
What openLuup does:
- runs the ALTUI plugin to give a great UI experience
- runs the MySensors Arduino plugin (ethernet connection to gateway only) which is really the main goal - to have a Vera-like machine built entirely from third-party bits (open source)
- includes a bridge app to link to remote Veras (which can be running UI5 or UI7 and require no additional software.)
- runs many plugins unmodified - particularly those which just create virtual devices (eg. Netatmo, …)
- uses a tiny amount of memory and boots up very quickly (a few seconds)
- supports scenes with timers and ALTUI-style triggers
- has its own port 3480 HTTP server supporting multiple asynchronous client requests
- has a fairly complete implementation of the Luup API and the HTTP requests
- has a simple to understand log structure - written to LuaUPnP.log in the current directory - most events generate just one entry each in the log.
- writes variables to a separate log file for ALTUI to display variable and scene changes.
What it doesn’t do:
- Some less-used HTML requests are not yet implemented, eg. lu_invoke.
- Doesn’t support the
<incoming>or<timeout>action tags in service files, but does support the device-level<incoming>tag (for asynchronous socket I/O.) - Doesn’t directly support local serial I/O hardware (there are work-arounds.)
- Doesn’t run encrypted, or licensed, plugins.
- Doesn’t use lots of memory.
- Doesn’t use lots of cpu.
- Doesn’t constantly reload (like Vera often does, for no apparent reason.)
- Doesn’t do UPnP (and never will.)
Latest release available now available on GitHub: GitHub - akbooer/openLuup: a pure-Lua open-source emulation of the Vera Luup environment
