OpenLuup: Rules Engine - Nothing Saving
So I am finally up and running with an Ubuntu OpenLuup install
AltUI is functioning
I have installed the Rules Engine
Initially I couldnt save a crated rule as I didnt copy the CGI-BIN folder to the cmh-ludl folder
I did that and and now it says saved
BUT…
Nothing shows in the display
HOWEVER… if I create another rule it says Expected XX rules, but received xx rules.
	Desynchronization : expected 0 rule(s) and found 1 in the xml file
has anyone else seen this and figured it out?
Where did you install it from? I believe that there’s a version specifically for openLuup on GitHub. Perhaps better ask on the Rules Engine thread.
ah… I just used the version from the last install
Whilst I have attention… this is pretty amazing work
Well done
