Assume code is as follows:
luup.call_timer(Timer_End_Light_Garage, 1, '5m')
Timer_End_Light_Garage should be string not a function pointer. openLuup says:
openLuup.context_switch:: ERROR: ./openLuup/luup.lua:385: attempt to concatenate a function value
Could this be altered to say something along the lines of:
openLuup.context_switch:: ERROR: ./openLuup/luup.lua:385: "function name 'Timer_End_Light_Garage' should be a string"
I’ve concentrated on getting the functionality of calls correct when used with the right parameters, rather than a fully comprehensive list of possible errors. Extensive parameter checking would slow down the system by some amount. But, along with a revamp of the error logging system, this is something which could be done better.
However, having made that mistake, you’re never going to do it again, are you? ![:wink: :wink:](https://community.ezlo.com/images/emoji/apple/wink.png?v=12)
The latest development branch update includes error checking for this (and also the new luup.ir.pronto_to_gc100() call.)
All luup functions which require text function names, rather than actual functions, use this. viz.
[ul][li]call_delay[/li]
[li]call_timer[/li]
[li]job_watch[/li]
[li]register_handler[/li]
[li]variable_watch[/li][/ul]
Instead of the previous obscure error at some point in the guts of openLuup, it now also reports the code line where the error occurred…
[string "ALTUI - LuaRunHandler"]:24: parameter #1 should be type string but is function
