I have managed to reload my user_data after several attempts and everything is back.
As with the scene editing … Yes I am using trash can and then submit. Sometimes when I add a trigger in it gets added 2 or 3 times and won’t let me delete ? Is this something you have seen before?
Edit by moderator:
This topic separated from a thread here: http://forum.micasaverde.com/index.php/topic,34480.msg272543.html#msg272543
Good. Glad about that.
As with the scene editing ... Yes I am using trash can and then submit. Sometimes when I add a trigger in it gets added 2 or 3 times and won't let me delete ? Is this something you have seen before?
No, I’ve not seen that at all… A copy of the log when you’re trying to edit would be most helpful.
I’ve had this happen before but it’s been awhile… I didn’t have too many scenes so I found the one where I first the WV, shut down openLuup and surgically removed it from the user_data.json. Keep a backup just in case.
[quote=“JCH, post:1, topic:191361”]I have managed to reload my user_data after several attempts and everything is back.
Sent from my iPhone using Tapatalk[/quote]
