I just wanted to express my gratitude to Akbooer for this innovative system and to CudaNet for his help in trouble shooting my setup to get it running.
[quote=“synapse007, post:1, topic:190795”]I just wanted to express my gratitude to Akbooer for this innovative system and to CudaNet for his help in trouble shooting my setup to get it running.
Thanks for the Pi instructions sure is saving me hours. Setting it all up on Raspbian Jessie Lite right now. I did find one minor suggested step order change. Do 11, step 5 (reload lighttpd) after 12 step 6 so the /www symlink is created.
I was also wondering if it is needed to create a /var/log/cmh folder or not for ALTUI?
I’ve found that almost all troubleshooting begins within the LuaUPnP.log and LuaUPnP.log.x. I discovered an issue on OpenWrt whereby the system would wipe that folder out completely on a restart. I didn’t discover it for days and it didn’t behave out of sorts. So, I’ll leave it at your discretion and if it happens to cause an issue then we can always make mention of it within the guide.
As always, I truly appreciate the feedback as it will help others…
Just to clarify: the /var/log/cmh folder is simply there to hold a specially formatted (Vera look-alike) subset of the log file which ONLY contains scene triggers and variable changes and which can be viewed by the default AltUI OS command ‘Tail Logs’.
There’s nothing there that isn’t in /etc/cmh-ludl/LuaUPnP.log
