Hello,
it’s not possible to modify attributes on openLuup (via ALTUI). It creates a new variable, with the same name as the attribute, and a service null.
I’ve checked with amg0 and it seems that it’s an openLuup bug.
Hello,
I thought I had fixed this - which version are you running?
The development branch on GitHub has a commit on Feb 2 “hot-fix-hhtp-attribute-set”.
[quote=“akbooer, post:2, topic:190971”]I thought I had fixed this - which version are you running?
The development branch on GitHub has a commit on Feb 2 “hot-fix-hhtp-attribute-set”.[/quote]
I run the Release 6.3. I will test the development branch.
I was having the same issue so I’ll give that a try too.
Cheers Rene
If you both confirm it works then I’ll merge with the master branch. Thanks.
Hi akbooer,
I puled all four files that seem to be new from the development tread and it seems to be working now. I can change the attributes from ALTUI just fine now. I do have a problem configuring the ip attribute but not sure if that is openLuup or ALTUI yet. I have to do some more testing.
Cheers Rene
Hello,
with the patch on the development branh, I can modify the attributes.
So it seems to be ok
