I have successfully been testing a version of the asynchronous I/O, in general, and specifically for VeraBridge. As hoped for, the latency is much lower, and there is somewhat less polling activity. I’ve tested common error conditions, including Luup reloads and Vera reboots.
The latest development release 2019.03.14 on GitHub is available for download. By default, the asynchronous VeraBridge is not enabled, but there is a device variable AsyncPoll which, if set to “true”, will enable it after a reload.
At the moment there are some additional log messages to check the behaviour, but overall, the only difference you should see is improved response times to Vera variable changes, and an additional socket named VERA async-tcp on the Console > Scheduler > Sockets page.
The bridge uses a new form of the http.request() which provides an asynchronous callback to the user when the response is received. In theory, this could be available to openLuup plugin developers to handle things like SOAP / AJAX calls, but that’s yet to be tested*.
If you care to try it, I’d welcome feedback.
* as discussed here: [url=http://forum.micasaverde.com/index.php/topic,111505.msg426879.html#msg426879]Using Soap onvif to listen for camera motion detection[/url]
