OpenKarotz Plugin
I’m currently developing a plugin to manage the Open Karotz Firmware version
At this moment, the enabled features are the following
  • set led color (SetColor - newTargetValue : 000000 to FFFFFF)
  • set led pulse (SetLedPulse - newTargetValue : 0 or 1)
  • set led pulse speed (SetLedPulseSpeed - newTargetValue : 0 to 2000)
  • set led pulse color 2 (SetColor2 - newTargetValue : 000000 to FFFFFF)
  • enable / disable Ears Management (SetEarsDisabled - newTargetValue : 0 or 1)
  • set right ear position (SetEarRight - newTargetValue : 1 to 10)
  • set left ear position (SetEarLeft - newTargetValue 1 to 10)
  • reset ears (ResetEars)
-set Karotz in sleep mode (SwitchPower1 - SetTarget : 0 or 1)
  • wakeup Karotz
To do List
  • Enable TTS
  • Choose TTS Voice
  • Enable Snapshot / Webcam
  • Play Sound
  • Radio
  • Play Moods
  • Play Funny Clock
I just submitted the plugin for Realease in its first version …
Link to the OpenKarotz firmware installation
http://www.openkarotz.org
cool… nice to read that !
Pierrick
Really nice!
Will this give the Karotz a more stable voice? When the original servers are down, my rabbit is silent.
Yes the rabbit is totally independent from the servers, but you need first to install openkarotz on the rabbit. After that, you can control it from a web ui or from this plugin !
Sent from my iPad using tapatalk
This plugin relies on http://www.openkarotz.org/
[quote=“chocorem, post:4, topic:182915”]Yes the rabbit is totally independent from the servers, but you need first to install openkarotz on the rabbit. After that, you can control it from a web ui or from this plugin !
Sent from my iPad using tapatalk[/quote]
Thanks I had already added it in the first post :innocent:
Bonjour chocorem, merci pour le plugin
but small message from my vera :
“OpenKarotz[54] : Startup Lua Failed” and “Device not ready”
Thierry
Hello , have you put the IP address in the settings ?
Yes I put the IP adress in the settings
Oui j’ai bien mis l’adresse IP.
Je suis en UI 5, firmware 1.5.622 et OpenKarotz Version : 219.1
I haven’t tested the published plugin… Will have a look asap
So the plugin needs a Json parser which is not included, I will fix this in further release. In the meantime, install google calendar plugin which contains one
It looks very promising !
Unfortunaly, I’ve got the same issue during Lua startup.
Google Calendar plugin is already install.
I’ve found a json.lua file in /usr/lib/lua/
I’ve check for a more detailled error in LuaUpnp.log and I’ve found the following error:
CallFunction_Startup-1 device 292 function KarotzStartup failed /usr/lib/lua/json.lua:213: Failed to scan c1;1mLuaInterface::1;1mLuaInterface::CallFunction_Startup-1 device 292 function KarotzStartuped /usr/lib/lua/json.lua:213: Failed to scan constant from stringr":“00FF00”,“secondary_color”:“000000”,“pulse”:“1”,“no_memory”:“0”,“speed”:“2000”,riled to scan constant from stringg eturn":“0”}
An issue with json.lua version ?
Many thanks for your help :wink:
O.
Where can i download the plug please ?
I would like to use the plugin as well, however it won’t start because of the same error as above.
I’m impressed by the openkarotz firmware though, I can choose the TTS-voice I like(3 for NL, I like!) and als have the karotz invoke scenes on the Vera.
Still figuring out how to let the rabbit speak from the vera(the only task it performed until now)
The existence of this Vera plugin persuaded me to install the Open Karotz firmware, which has very good functionality.
Unfortunately, like others have reported, I get the Startup Lua Failed error in Vera. As suggested, I tried installing of Google Calendar plugin (both plugin versions), but this did not fix the issue.
I hope development of the Vera plugin continues, as I can see me using it every day for status notifications etc.
Dear Karotz owners,
I’m looking for solution (possible an (open)Karotz device) that allows me:
  • Blink lights based events send from a device like Vera
  • Speak based on events from a device like Vera
I want to use it to actively inform me in my living room about events like a doorbell or movement.
Now I know that Karotz is not being shipped anymore… Is there something similar on the market that can be bought or easily be build?
If not does any of you know if there is still a hidden stash of Karotz out there that someone would sell?
Cheers and thanks!
mca
