[quote=“guessed, post:2, topic:186394”]Multiswitch has no built in defaults in the MiOS Binding, so sending it an [tt]ON[/tt] Command does nothing.
If you work out what the defaults should be, then they can readily be added to the Binding. I don’t use Multiswitch, so it’s arduous to work it out.
The defaults are in [tt]openhab/binding/mios/internal/config/DeviceDefaults.properties[/tt], and typically go hand-in-hand with one or more [tt]OH/configuration/transform/mios*.map[/tt] files that actually turn the values into the required UPnP Action call.[/quote]
I’ve been using mutliswitch a lot. Mainly to put a bunch of buttons into my Vera that I can then use to trigger things in OpenHab. For example, I have 8 different “modes” for my heating and A/C. I use a multiswitch in Vera set as radio buttons. This way I can control them from both UI7 and from HomeWave, which is my preferred iPhone client.
I’ve mapped them like this, and it works fine.
Switch HVACModesMS_Manual "HVACModesMS Manual" (gMultiSwitch) {mios="unit:house,device:142/service/urn:dcineco-com:serviceId:MSwitch1/Status1,command:ON=urn:dcineco-com:serviceId:MSwitch1/SetStatus1(newStatus1=1)|OFF=urn:dcineco-com:serviceId:MSwitch1/SetStatus1(newStatus1=0),in:MAP(miosSwitchIn.map),out:MAP(miosSwitchOut.map)"}
Switch HVACModesMS_Auto "HVACModesMS Auto" (gMultiSwitch) {mios="unit:house,device:142/service/urn:dcineco-com:serviceId:MSwitch1/Status2,command:ON=urn:dcineco-com:serviceId:MSwitch1/SetStatus2(newStatus2=1)|OFF=urn:dcineco-com:serviceId:MSwitch1/SetStatus2(newStatus2=0),in:MAP(miosSwitchIn.map),out:MAP(miosSwitchOut.map)"}
Switch HVACModesMS_Auto_Heat "HVACModesMS Auto Heat" (gMultiSwitch) {mios="unit:house,device:142/service/urn:dcineco-com:serviceId:MSwitch1/Status3,command:ON=urn:dcineco-com:serviceId:MSwitch1/SetStatus3(newStatus3=1)|OFF=urn:dcineco-com:serviceId:MSwitch1/SetStatus3(newStatus3=0),in:MAP(miosSwitchIn.map),out:MAP(miosSwitchOut.map)"}
Switch HVACModesMS_Steady_Heat "HVACModesMS Steady Heat" (gMultiSwitch) {mios="unit:house,device:142/service/urn:dcineco-com:serviceId:MSwitch1/Status4,command:ON=urn:dcineco-com:serviceId:MSwitch1/SetStatus4(newStatus4=1)|OFF=urn:dcineco-com:serviceId:MSwitch1/SetStatus4(newStatus4=0),in:MAP(miosSwitchIn.map),out:MAP(miosSwitchOut.map)"}
Switch HVACModesMS_Auto_Cool "HVACModesMS Auto Cool" (gMultiSwitch) {mios="unit:house,device:142/service/urn:dcineco-com:serviceId:MSwitch1/Status5,command:ON=urn:dcineco-com:serviceId:MSwitch1/SetStatus5(newStatus5=1)|OFF=urn:dcineco-com:serviceId:MSwitch1/SetStatus5(newStatus5=0),in:MAP(miosSwitchIn.map),out:MAP(miosSwitchOut.map)"}
Switch HVACModesMS_Steady_Cool "HVACModesMS Steady Cool" (gMultiSwitch) {mios="unit:house,device:142/service/urn:dcineco-com:serviceId:MSwitch1/Status6,command:ON=urn:dcineco-com:serviceId:MSwitch1/SetStatus6(newStatus6=1)|OFF=urn:dcineco-com:serviceId:MSwitch1/SetStatus6(newStatus6=0),in:MAP(miosSwitchIn.map),out:MAP(miosSwitchOut.map)"}
Switch HVACModesMS_Away_Heat "HVACModesMS Away Heat" (gMultiSwitch) {mios="unit:house,device:142/service/urn:dcineco-com:serviceId:MSwitch1/Status7,command:ON=urn:dcineco-com:serviceId:MSwitch1/SetStatus7(newStatus7=1)|OFF=urn:dcineco-com:serviceId:MSwitch1/SetStatus7(newStatus7=0),in:MAP(miosSwitchIn.map),out:MAP(miosSwitchOut.map)"}
Switch HVACModesMS_Away_Cool "HVACModesMS Away Cool" (gMultiSwitch) {mios="unit:house,device:142/service/urn:dcineco-com:serviceId:MSwitch1/Status8,command:ON=urn:dcineco-com:serviceId:MSwitch1/SetStatus8(newStatus8=1)|OFF=urn:dcineco-com:serviceId:MSwitch1/SetStatus8(newStatus8=0),in:MAP(miosSwitchIn.map),out:MAP(miosSwitchOut.map)"}
guessed, I don’t know if that will help you get those into the binding or not. If so, cool. If not, no big deal.
Thanks,
Doug
