How hard can that be?
Seems like such a basic function that could be combined with a simple timer based system.
I run 6-8 timers for Garden and Lawn.
I don’t need to analyze soil or plant types. I just water each section 20 minutes a day and all is fine. My Tomatoes are usually 8 feet high and I need ladder to pick the cherry tomatoes.
I don’t want an Irrigation System. Doesn’t work well with Garden. Also if installed in lawn it raises my Tax Bill or Water Rate (I forget).
The Timers have worked great for years. But it is wasteful. I try to turn them off if things are wet or will be wet. But sometimes I forget and leave it on or leave it off.
Water Moisture meters are not right for this. You want things to stay moist all the time. It’s really based on inches of water per week. And you really want past precipitation to be factored in (more than future forecast which is not always reliable, but past should be).
I shouldn’t have to install a rain gauge to make this work.
So how much work would this be to make work on Vera, or any other home automation system.
I’m tempted to buy a Irrigation Controller that does exactly this, add a sensor to the output valve and if that is on, then open the valve :).
But that seems a bit silly. Gosh this shouldn’t be so hard.
Suggestions?
