Onkyo Receiver Plugin and Bluetooth input
I have been looking for a solution for a while now and can’t seem to find one. I have an Onkyo TX-NR838 Receiver and am using the Onkyo Plugin for various scenes. Most are working well but I cannot figure out how to configure a scene to get the Bluetooth source to play on my remote zones (Z2 or Z3). (For clarification, I can do it manually with the Onkyo remote, but not with a scene in Vera). I realize the Plugin was most likely developed before the receivers supported Bluetooth and there appears to be no direct Bluetooth Input command, so I am wondering if there is a way to cycle through the inputs - even one at a time.
I have tried the following:
  1. set up a scene that powers on Zone 3 and then after a second delay, runs the Source command - have tried the source command up to 12 times and can’t get to Bluetooth
  2. I also set up a scene that powers on Zone 3 and then, after a second, runs the ToggleInput command - have tried the ToggleInput command many times in a row as well with no success.
Any help is much appreciated - Thanks
See this post for more info on enabling Bluetooth: [url=http://forum.micasaverde.com/index.php/topic,17811.msg318831.html#msg318831]http://forum.micasaverde.com/index.php/topic,17811.msg318831.html#msg318831[/url]
I’ll work toward adding a button in the UI for it as I have free time…
