I have a situation that I believe to have a solution but it might require some outside-of-the-box thinking.
I run a wedding venue. The main building uses a VeraPlus to control all lights, fans, blinds, firepit, AC’s, etc… (140+ devices at the moment). Everything is great!!
Now, I am about to add some decorative lights by the front gate of the property (about 1,000-ft away from the main building). I would ABSOLUTELY love it if they could be controlled by the same scenes on the main Vera. As the new lights are clearly too far away to be part of the Z-Wave network, I have come up with only 2 ways of controlling it directly from the main Vera:
I would need to run a low-voltage line all the way down to the gate and use a contact/relay setup to control the lights directly off of the main Vera. ( >:(Definitely not the preferred method)
OR
Install an additional Vera down by the gate to control the lights. (There is a building that is nearby the gate that could provide Wi-Fi and I could setup the new Vera with Wi-Fi Bridge Mode). The issue here is that the main building and the building by the gate are on 2 COMPLETELY different networks (even 2 different ISP’s). I know that Vera’s can be setup in “Bridge” mode so that the Main Vera could control the Gate Vera but I am under the impression that they MUST be on the same LAN.
So, if you haven’t figured it out yet, my question is:
Is there ANY way for the Main Vera to control/trigger devices on the Gate Vera over the internet? Is there a plugin that can be implemented or some kind of protocol that can be utilized to allow one Vera to be triggered by the actions of another over the internet?
Any help would be greatly appreciated. Thanks so much!
-Ryan
