I have four PLEG Devices. However one of them seems to be stuck.
Look at the dates on the attachment.
I tried deleting a couple of the the triggers and reentering them with a different name, but then it leaves the dates of the of the ones I reentered on/off dates empty.
I am able to make edits everywhere just like if it was working.
And yes, it is Armed
Jim
Changes do not take effect until the next time you reload.
In general I do not respond unless a PDF of the STATUS report is provided.
I reloaded, rebooted, unplugged/replugged the Vera Plus trying to get this Device going.
Attached is the PDF of the Status Report
While waiting for you to respond, I tried this:
- Backed up Vera Plus
- Backed up non-working PLEG Device (Cellular Events)
- Deleted Cellular Events PLEG Device
- Created new PLEG Device
- Attempted to restore Cellular Events into new PLEG Device from Backup.
When I hit the Verify Button, It gave me a few errors (Can’t find Cellular Events & Parameter not found)
And it refused to load.
- I restored from the entire Backup from Step 1, and I am back where I started
I turned on the log and reloaded the LUA Engine.
I attached the PDF per your instructions. I’m not sure if I got it right
Your LOOKING in the wrong place !!!
PLEG only wakes up on events. NO EVENTS … NO CHANGE in status.
Nothings going to happen until your iphone plugin starts reporting events.
[quote=“RichardTSchaefer, post:5, topic:198246”]Your LOOKING in the wrong place !!!
Nothings going to happen until your iphone plugin starts reporting events.[/quote]
The iPhone plugin is reporting events to my other PLEG devices.
See the attached working SLight PLEG Device Status on the same Vera Plus
Since five people downloaded the working SLight PLEG Device Status Report several days ago from my last post without anyone providing a solution, I decided to:
- Disarm the Cellular Events Device (It repeatedly gave me an error and would not set to Bypass)
- So I deleted the Cellular Device
- Created a new Cellular Events PLEG device
- Copied and pasted each Trigger, Condition, and Logic Actions and from the old Cellular Events PLEG device Status Report into the new Cellular Events PLEG Device.
And now it works. It was probably the easiest solution in the first place.
