One controller for multiple receptacles?
I’d like to install a new circuit with 6-7 receptacles for outdoor Christmas lights. Is there one z-wave device/relay I can insert at the beginning of the circuit to turn on/off all the receptacles at the same time? I plan to use a 15-amp GFCI breaker for this circuit. I’ve found a few relays on-line but they don’t seem suitable for a 15-amp circuit.
-Ray
New circuit? Couldn’t you make it a switched circuit, and install a z-wave switch? You couldn’t use 15A with that, but is your load really 15A?
[quote=“Ray-T, post:1, topic:184732”]I’d like to install a new circuit with 6-7 receptacles for outdoor Christmas lights. Is there one z-wave device/relay I can insert at the beginning of the circuit to turn on/off all the receptacles at the same time? I plan to use a 15-amp GFCI breaker for this circuit. I’ve found a few relays on-line but they don’t seem suitable for a 15-amp circuit.[/quote]The Linear FS20Z-1 Z-Wave in Wall Fixture Module could be used for this application. It is capable of switching up to 20 amps.
The Linear FS20Z-1 is just what I’m looking for. Thanks Z-Waver
