Hi!
I have vera lite that works ok. But have one problem.
At first startup vera get 192.168.99.14 ip from dhcp. After setting zwave network i tell dhcp server to give vera 192.168.99.50 static ip.
When I try to connect to vera out of home i go to http://home.getvera.com
I see my vera and press “Go to local UI” it goes to .50. But some programs see old ip adress.
I see ip in https://cp.mios.com/mysystems.php
Unit_XXXXXX
Serial #XXXXXXX // IP: 192.168.99.14
Some android programs like Vera mobile can’t connect to my vera because they see old ip.
I read wiki http://wiki.micasaverde.com/index.php/UI_Notes and go to
http://sta1.mios.com/locator_json.php
It returns old ip:
{“units”:[{“serialNumber”:“XXXXXXXX”,“FirmwareVersion”:“1.5.286”,“name”:null,“ipAddress”:“192.168.99.14”,“users”:[],“active_server”:“fwd7.mios.com”,“forwardServers”:[{“hostName”:“fwd7.mios.com”,“primary”:true},{“hostName”:“fwd8.mios.com”,“primary”:false}]}]}
Please help to change ip.
oTi@, thanks once again for keeping a close eye on the forum and fixing the link.
trying:
http://192.168.99.50/cgi-bin/cmh/ReportStatus.sh?PK_AccessPoint=35110853
responses: OK:35110853
But no results.
running Report_AP.sh over ssh
no results too.
New MiOS systems on your home network
I found 1 new MiOS systems which have not yet been assigned to a MiOS account. Click “Add to MiOS account” if you want to setup or use these systems.
Unit_35110853
Serial #35110853 // IP: 192.168.99.14
root@MiOS_35110853:~# ifconfig
eth0 Link encap:Ethernet HWaddr 00:0E:8F:43:E5:BF
inet addr:192.168.81.1 Bcast:192.168.81.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1037 errors:0 dropped:189 overruns:0 frame:0
TX packets:634 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:310857 (303.5 KiB) TX bytes:85819 (83.8 KiB)
Interrupt:5
eth0:0 Link encap:Ethernet HWaddr 00:0E:8F:43:E5:BF
inet addr:192.168.99.50 Bcast:192.168.99.255 Mask:255.255.255.0
Interrupt:5
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:15223 errors:0 dropped:0 overruns:0 frame:0
TX packets:15223 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:3254063 (3.1 MiB) TX bytes:3254063 (3.1 MiB)
Just an fyi, I would highly suggest that you up date the firmware on your vera unit. You are running a very old firmware.
A things to consider.
Reboot your router will release the assigned IP addresses.
Reboot Vera should report change back to Mios
As Garrett said above. There were a number of fixes in the more recently releases.
