Would there be any possibility to port the code to work with OEM Branded Vera Edges? They still have a similar web portal as the Vera, but just rebranded for that specific OEM. I can supply an example and test device.
Until Richard pings in I want to add that if OEM unit is running the equivalent of UI7, you should not have any issues running the same apps as you would on Vera. With some exceptions where some OEM block this feature. But if you have the Apps menu, you should be able to do this.
It is running UI7 and has the app menu. The problem that I had is that you don’t create a vera account. The login goes directly to MIOS.
