My Vera3 UI5 isn’t all that stable, seems to work for a while, then stop. Sometimes it’ll start working again magically, sometimes it’ll require a unplug/plug cycle.
I have logging set up to log to a USB thumbdrive.
I decided to SSH in and see what I could find in the logs, but it looks like the log filenames don’t match what I’ve found in the docs.
Mount shows the following:
/dev/sda1 on /tmp/log/cmh type ext3 (ro,noatime,nodiratime,errors=continue,barrier=0,data=ordered)
(should that be ro??)
However, nothing’s being written to cmh, it all lives a level up…
root@MiOS_30010480:/tmp# ls -altr
drwxr-xr-x 1 root root 0 Feb 18 16:51 ..
drwxr-xr-x 2 root root 40 Mar 20 17:48 overlay
-rw-r--r-- 1 root root 295 Mar 20 17:48 log.platform_init
-rw-r--r-- 1 root root 23 Mar 20 17:48 TZ
drwxr-xr-x 3 root root 60 Mar 20 17:48 usr
drwxr-xr-x 2 root root 40 Mar 20 17:48 opkg-lists
-rw-r--r-- 1 root root 5507 Mar 20 17:48 log.fix_datetime
drwxr-xr-x 2 root root 60 Mar 20 17:48 alerts
-rw-r--r-- 1 root root 20 Mar 20 17:48 .mios.squashfs_mounted
-rw-r--r-- 1 root root 0 Mar 20 17:48 dhcp.leases
-rw-r--r-- 1 root root 2227 Mar 20 17:48 log.Provision
drwx------ 2 root root 80 Mar 20 17:48 .uci
drwxr-xr-x 2 root root 100 Mar 20 17:48 state
-rw-r--r-- 1 root root 2 Mar 20 17:48 recover_switch_mode
-rw-r--r-- 1 root root 51 Mar 20 17:49 resolv.conf.auto
drwxr-xr-x 3 root root 60 Mar 20 17:49 spool
-rw-r--r-- 1 root root 741 Mar 20 17:49 log.freshinstall
-rw-r--r-- 1 root root 1502 Mar 20 17:49 log.RouterMode
-rw-r--r-- 1 root root 21 Mar 20 17:49 log.SetupRemoteAccess
drwx------ 3 root root 60 Mar 20 17:49 lib
-rw-r--r-- 1 root root 1208 Mar 20 17:49 log.opkg
-rw-r--r-- 1 root root 5964 Mar 20 17:49 log.mios_firmware
drwxr-xr-x 2 root root 80 Mar 20 17:49 lock
drwxr-xr-x 2 root root 40 Mar 20 17:49 buffer
-rw-r--r-- 1 root root 456 Mar 20 17:49 log.check_internet
drwxr-xr-x 4 root root 120 Mar 20 17:49 log
drwxr-xr-x 4 root root 360 Mar 20 17:49 run
-rw-r--r-- 1 root root 13 Mar 20 17:49 nm_ip_last
-rw-r--r-- 1 root root 32 Mar 20 17:49 resolv.conf
-rw-r--r-- 1 root root 1 Mar 20 17:49 ip_mode
-rw-r--r-- 1 root root 0 Mar 20 17:49 log.mios_services
-rw-r--r-- 1 root root 2174 Mar 20 17:49 log.Report_AP
-rw-r--r-- 1 root root 93 Mar 20 17:49 streaming.hreadable
-rw-r--r-- 1 root root 0 Mar 20 17:49 3482forwarded.lock
-rw-r--r-- 1 root root 44 Mar 20 17:50 log.cmh-ra-daemon
-rw-r--r-- 1 root root 2 Mar 20 17:50 .cmh-ra-sleep_time
-rw-r--r-- 1 root root 11 Mar 20 17:50 .cmh-ra-connected
-rw-r--r-- 1 root root 4256 Mar 20 18:49 log.Init-NetworkMonitor
-rw-r--r-- 1 root root 13 Mar 20 19:05 ip_wan
-rw-r--r-- 1 root root 12 Mar 20 19:05 ip_lan
-rw-r--r-- 1 root root 21986 Mar 21 17:51 log.cmh_PnP.gz
-rw-r--r-- 1 root root 14 Mar 22 05:49 lastip
-rw-r--r-- 1 root root 11 Mar 22 05:49 .time_synced
-rw-r--r-- 1 root root 11 Mar 22 05:51 logrotate_timestamp
-rw-r--r-- 1 root root 141183 Mar 22 05:51 log.LuaUPnP.gz
-rw-r--r-- 1 root root 0 Mar 22 11:03 log.no_internet
-rw-r--r-- 1 root root 142 Mar 22 11:03 log.sysinfo
-rw-r--r-- 1 root root 1294 Mar 22 11:03 log.upgrade
drwxr-xr-x 2 nobody nogroup 40 Mar 22 11:26 pnp.lock
-rw-r--r-- 1 nobody nogroup 105144 Mar 22 11:26 log.cmh_PnP
-rw-r--r-- 1 root root 754 Mar 22 11:33 log.Init-LuaUPnP
-rw-r--r-- 1 root root 1453 Mar 22 11:33 log.Fix_HomeID
-rw-r--r-- 1 root root 0 Mar 22 11:33 server_backup
-rw-r--r-- 1 root root 50260 Mar 22 11:33 luaupnp.xml
-rw-r--r-- 1 root root 1 Mar 22 11:33 zwave_state
-rw-r--r-- 1 root root 5478 Mar 22 11:33 log.lighttpd_error
-rw-r--r-- 1 root root 127654 Mar 22 11:33 log.cmh-ra-keepalive
-rw-r--r-- 1 root root 3611 Mar 22 11:33 log.proxy.sh
-rw-r--r-- 1 root root 0 Mar 22 11:34 usb.logging
-rw-r--r-- 1 root root 173747 Mar 22 11:34 log.Rotate_Logs
drwxrwxrwt 15 root root 1240 Mar 22 11:34 .
-rw-r--r-- 1 root root 776171 Mar 22 11:34 log.LuaUPnP
Something else that seems odd - /etc/fstab is a symlink to /tmp/fstab, which doesn’t exist.
I’ve put some time into adding all my devices and setting up rules, I’d hate to have to re-do it all from scratch.
Is the above correct? (sure seems not). Any ideas how to go about fixing it?
