I am a new veralite user and just bought a Fibaro FGR221 module. I seem to be getting a odd behavior which I cannot understand.
I use UI5 and latest firmware 1.5.322
I have a bistable switch so I have set parameter 14 to 1
When I use the switch on the wall, I can open the shutter fine and I can close it fine manually
When I use the device dialog box actions on the Vera controller, I can also press close and it closes fine , same for open.
So I guess/hope my cabling is correct
The problem is : in the vera device dialog actions, if I press “Up” it goes down and if I press “Down”, it goes up. I of course tried to change the cabling in the wall but then it is the Open/Close that gets wrong.
See the attached file (at the bottom of the post), it can be uploaded through the Vera UI and it will override the WC current file, reversing the up and down buttons to be correct. It will work for all window covering devices, not just the ZRTSI. When the new firmware comes out, you can just delete/remove my file and use the switch in advanced settings (assuming that’s where they’ll put it).
