I have a few Minoston MP21Z and MP21ZP plugs that I’ve been using without any issues until recently.
The only difference between the two plugs is that the “ZP” model has a power meter to monitor electrical draw through the plug. I haven’t encountered any issues with the “Z” plugs to date.
I recently shut down my electricity-hungry home lab setup and moved workloads over to a few Intel NUC devices and a fanless firewall appliance. In the process, I’ve reduced my electrical draw from about 700W continuous to about 30W continuous. Two of the NUC devices that I am using are NUC5 boxes and I have them plugged into the “ZP” plugs. One has been running just fine, but the other has been acting odd.
I power on the plug (which automatically powers on the NUC). The device boots up and runs normally for anywhere from about 24-36 hours and draws 7-8W max at any point. Then, the plug encounters some sort of issue and goes into a sort of “tripped” state where the light on the side flashes slow and you have to unplug it and plug it back in to get it to operate again.
I contacted Minoston to inquire about troubleshooting (or maybe even adjusting settings) and then simply said “we’ll send you a new one.” Great. But… in the meantime, I swapped it for another new (fresh out of the box) “ZP” plug and it did the same thing.
I’m basically wondering if anyone has any experience with these plugs specifically, or maybe ones that are materially similar. These are rated for 15A/1875W of resistive or general purpose load, and 5A/625W load for a tungsten filament type of draw. The actual draw I am seeing on these is less than 1/10 of an amp (.1A), but the load is an AC->DC power converter “brick” (like a laptop power supply, if you will).
The “Z” plugs are rated at 10A resistive load capacity.
Anyone have any thoughts?
