Nx panel not triggering scenes
@futzle
My alarm connection is stable and I can manipulate the system with the plugin interface and physical interfaces (keypads and key fob remotes). I am currently on ui5 with version 69 of the nx-8 plugin.
I used to have the act of arming and disarming trigger scenes to shut everything down and lock the house when the system was armed and unlock everything when the system was disarmed. I noticed that those scenes do not run anymore and I don’t believe anything has changed in the panel or on settings for vera or the plugin.
How do I get those running again?
Did the plugin change?
Is it possible that vera changed?
I have it set to trigger off the armed state being armed or not armed.
What am I missing? Any help troubleshooting is appreciated.
Drew
Hi drew,
You’re right, that part of the plugin hasn’t changed in years.
Some sanity checks: look at the Advanced tab of the panel while disarmed. Note the values of variables. Close the tab. Now arm the partition (which should fire off your scene, but now isn’t). Now return to the Advanced tab. Have variables changed?
