Hello.
I have just purchased and connected an NX-584 module for my NX-6 Alarm panel. My intention is to integrate with my Vera2 Controller. Can someone help with the steps I need to follow for enrollment of the device through the alarm panel? I understand and get good results from the following instructions:
To enter the Program Mode:
Enter [*]-[8] (all of the function key LEDs will begin to flash).
Enter the “Go To Program” code (default is [9]-[7]-[1]-[3]). If the code was valid, the
Service LED will flash, and the function LEDs will illuminate steady, indicating the device
to program should be entered.
Enter the address of the NX-584, which is [7] [2] followed by [#]. At this point, the Armed LED
will illuminate while it is waiting for a programming location to be entered
What I need help with are next steps and what the programming locations are. I have no idea what this means:
Enter the desired programming location followed by the [#] key.
The Armed LED will begin to flash while a programming location is being entered. If this
is a valid location, the Armed LED will extinguish, the Ready LED will illuminate, and the
binary data for the first segment of this location will be shown on the zone LEDS.
If the desired location is the next sequential location, press the [POLICE] key.
If the previous location is desired press the [FIRE] key.
If the same location is desired press the [AUXILIARY] key.
