I used the “I_Dlink5300.xml” luup file and modified it so that now PTZ functions on IPUX cameras. I disabled the zoom function buttons since they are not used on the IPUX. I tested and it works for my IPUX 2330 cam.
However I would like to add code to this to also have my 8 IPUX presets working. I am using the Generic cam in UI5 on a Vera3. I have no preset buttons when I go into the wrench.
How can I add buttons in the Generic cam UI? I think I can sort out mapping them.
Also I am a newbi and so I don’t know how to post my I_PUX2330.xml file here if somebody wants to use it.
Thanks.
here is the file code:
<?xml version="1.0"?>
<implementation>
<functions>
function lug_startup(lul_device)
lug_Username = luup.devices[lul_device].user
lug_Password = luup.devices[lul_device].pass
lug_Path = luup.variable_get("urn:micasaverde-com:serviceId:Camera1", "URL", lul_device)
if (lug_Path == nil or lug_Path == "" ) then
luup.variable_set("urn:micasaverde-com:serviceId:Camera1", "URL", "/cgi-bin/video.jpg?size=3", lul_device)
</functions>
<startup>lug_startup</startup>
<actionList>
<action>
<serviceId>urn:micasaverde-com:serviceId:PanTiltZoom1</serviceId>
<name>MoveLeft</name>
<job>
luup.inet.wget('http://' .. luup.devices[lul_device].ip .. '/admin/ptctl.cgi?move=left',5,
lug_Username, lug_Password)
</job>
</action>
<action>
<name>MoveRight</name>
<job>
luup.inet.wget('http://' .. luup.devices[lul_device].ip .. '/admin/ptctl.cgi?move=right',5,
</job>
</action>
<action>
<name>MoveUp</name>
<job>
luup.inet.wget('http://' .. luup.devices[lul_device].ip .. '/admin/ptctl.cgi?move=up',5,
</job>
</action>
<action>
<name>MoveDown</name>
<job>
luup.inet.wget('http://' .. luup.devices[lul_device].ip .. '/admin/ptctl.cgi?move=down',5,
</job>
</action>
</actionList>
</implementation>
