No … I can not get it to work correctly.
It seems that the wattage peaks sometimes , although the computer is off.
What I want is this:
-A notification when the computer is switched on
-A notification when the computer is switched off
This can only be “read” by means of the wattage used , since the Qubino relais will always be on , the relais is just there for checking by wattage if the computer is on or off.
I made 2 triggers , one above 30 watts , one below 10 watts
( when the computer is on, the wattage is minimum 35 , and peaks to 60 with an average of 40)
I made 2 timers of 10 seconds , which are run by the 2 triggers.
-A_Computer_Timer_wattage_above
-A_Computer_Timer_wattage_below
and these 2 conditions to start the timers:
A_Computer_wattage_above
A_Computer_wattage_below
and these 2 conditions for a notification to run:
A_Computer_wattage_above AND ( A_Computer_wattage_above; !A_Computer_Timer_wattage_above )
A_Computer__wattage_below and ( A_Computer__wattage_below; !A_Computer_Timer_wattage_below)
4 actions:
2 for the timers to run:
2 for the notification to send
BUT; it doesn’t work , the computer has been off for example since last night , and I recieved about 7 messages that the computer is off . meaning , the condition “A_Computer__wattage_below and ( A_Computer__wattage_below; !
A_Computer_Timer_wattage_below)” was true for 7 times.
What am I doing wrong here? I do understand when there is a peak wattage, the wattage goes above 10 watts , timers is run , and that the condition “A_Computer__wattage_below and ( A_Computer__wattage_below; !
A_Computer_Timer_wattage_below)” becomes true … every time.
What should I do to recieve the notification only once.
Maybe something that the condition can only be true after the other condition has been true. Or maybe something completely different :-X
Thanks,
Cor
