Notification when device is running for certain time
Hello, new to reactor as I am (maybe was) using PLEG.
I managed to get around with the very first steps. Also receive a pushover notification via Veraalerts.
A little help please: I want to be notified when a device is running for 30 minutes. How can this be done with Reactor? So how to make that condition?
The simple way is it that you add the condition of device state on, then hit the little drop down arrow in the top left and select pulse. I think the value is in seconds so 1800 in that box.
Save that, then over to activities: When the condition is true select notify.
Doe that help?
C
Thanks. Doesn’t seem to work. I get the notification directly when the device is activated.
In the state of the reactorsensor I see the pulse counting… But thats it.Capture
Got it, it was a bit lower in de settings, there is a restrictions part with the sustained option:
Capture1
Now I get the notification after 60 secs.
So sorted?
C
Yes, it’s working great!
