Notification when a scene is activated/run
I can not imagine this hasn’t been asked before, but I can’t find an answer with the search function.
What would be the easy way to get a notification when a scene is run? I don’t see a "“notification tab” on the scenes.
I can think of a way , inserting a virtual switch which is toggled and sending the notification or via PLEG. But just a simple LUUP code would be the most easiest I think.
Many thanks,
Cor
You can do this without LUA …
In the Advanced tab for a scene … Add the notification device, my Favorite is Vera Alerts, but I am biased …
Then add the appropriate action for the particular notification plugin …
For Vera Alerts it’s called SendAlert … and use one or more of your profile names or Vera Users as the recipient(s).
Cool , I got it working. Thanks.
And yes, it’s my favourite as well :slight_smile:
Cor
Perfect, worked for me.
