Notification sounds
So i set up Vera Alerts, and it’s working…but…
In the phone app there is 5 “alert levels” that you can change the sound for.
How in earth can I set different notification sound for each device?
I want a specific notification sound if my garage door is opened,
and a different sound if my fire alarm triggers.
Can’t figure out how to do this.
{tone:X}
Where X equals the number of the tone you want to play from 1 - 5.
Example: {tone:2}{BGColor:Green}The garage door has been opened.
Yes I know that but there is only place for one sound in the Vera Alerts plugin.
Or do I have to create a new profile for each device?
Don’t worry about the Vera Alerts Plugin. Open the Vera Alerts app on your Android device, go to Settings, scroll down to Alert 1 (default), Alert 2, etc. Tap on any of the alert numbers there and browse for the sound you want to use.
Sorry if I’m not understanding your issue 100%.
ok, the problem is I want different sound for different things.
If my garage door opens I want certain sound.
If my front door is opened I want some other sound sound etc.
So how do I choose which device play which of the 5 sounds?
You’d do this:
Upload 5 different sounds. For this explanation, we’ll call them sound1, sound2, sound3, sound4 and sound5.
To upload each sound, you’ll go to settings → select each Alert number, and browse to the corresponding sound file. (sound1, sound2, etc).
Once that is set, you’ll go into your Vera Scenes, create a scene when you door opens, add a Vera alert notification for each sound:
{tone:1} <— that would play your sound1 sound file.
Another scene for your front door would be a Vera alert notification with the text:
{tone:2} <— that would play your sound2 sound file.
Rinse and repeat for all five sounds.
This doesn’t sound right.
Do I really have to create a scene just to play a certain notification sound?
I tried to do that but there is nowhere I could:
“add a Vera alert notification for each sound”
Where in earth do I type the:
{tone:1}
Sorry, but I’m totally out…
There Vera Alerts mobile support the ability to embed Sound Files Names in the message. This is called earcons
i.e. a message:
Stop … attack … <>
See:
http://forum.micasaverde.com/index.php?topic=13191.0
Is it in the “message override” section in the vera alerts plugin i write the “{tone:1}” etc ?
Doesn’t anybody really know how to do this?
[quote=“thief, post:9, topic:198606”]Is it in the “message override” section in the vera alerts plugin i write the “{tone:1}” etc ?
Doesn’t anybody really know how to do this?[/quote]
I explained how to do this exactly in my post. You need to create a Vera scene for these. Let me know if you need a detailed guide on how to do it step by step.
