Nothing changed in my setup. I use Veramate premium 10.12.2.1
my luup code is : luup.call_action(“urn:veramate-com:serviceId:VeraMatePN”, “SendAlert”, {Msg=TriggerName}, 22)
It used to send me an alert on my iphone but since yesterday, nothing anymore… I tried to reinstall the app, made sure notifications were ON.
I get only this in the logs :
08 06/17/16 18:44:23.942 JobHandler_LuaUPnP::HandleActionRequest argument Code=luup.call_action(“urn:veramate-com:serviceId:VeraMatePN”, “SendAlert”, {Msg=TriggerName}, 22) <0x74200520>
08 06/17/16 18:44:23.942 JobHandler_LuaUPnP::HandleActionRequest device: 22 service: urn:veramate-com:serviceId:VeraMatePN action: SendAlert
Also saw that a little bit later :
LuaInterface::CallFunction_Job device 22 function SVeraMateAPN_VeraMatePN_SendAlert_run failed [string “…”]:28: attempt to index local ‘lul_settings’ (a nil value) <0x74200520>
Any idea ?
IOS report Connection type Cellular (even if I’m on wifi (!) )
server : vera-us-oem-relay31.mios.com
Last updated: (almost now…)
authentification : MMS (UI6/7)
device loaded : 14
scene loaded : 10
memory live : 78 mb
Current command (1) Data refresh (all the time)
