Not getting notifications with Vera Alerts
Hi all.
I can’t get Vera Alerts to:
  1. Send mail from the Send Alert Tab (but alert to Android App works)
    2 Send mail OR alert from a device notification.
    3 {timestamp} doesn’t surface a time in the messaged received on the phone.
Here’s my config:
Vera Lite. UI15. Vera Alerts 5.7. email out:msn (outlook.com) email in gmail. I have tried reversing these as well.
User to Profile Mapping Shows as I’d expect.
MyUserName MSF-Note3,email-MSF
Settings shows 2 Profiles assigned to my UserName
1st is for Android (Galaxy Note 3)
Contains correct ID and {timestamp} in the prefix field.
2nd for email contains my email addresses:
Subject Vera Notification {Picture(72)}
To Name@gmail.com
From Name@msn.com
SMTP-Server smtp-mail.outlook.com
SMTP-Port 587
SMTP-UserName Name@msn.com
SMTP-Password Correct
SMTP-Authentication true
SMTP-SSL true
I’ve tried a different port (25). I’ve tried using smtp.gmail.com (with appropriate gmail account info) to send as well. No joy.
I have been testing on a door sensor and I get the MCV notification as expected but not the Vera Alerts.
Here’s the log from using Send tab (note names obfuscated):
12:51:00.420 luup_log:103: VeraAlert:103:SendAlert:Msg:tusting testing <0x2b82b000>
50 06/25/14 12:51:00.421 luup_log:103: VeraAlert:103:ExpandRecipients:Checking:MyUserName <0x2b82b000>
50 06/25/14 12:51:00.421 luup_log:103: VeraAlert:103:ExpandRecipients:Adding User Specified Profile:MSF-Note3 <0x2b82b000>
50 06/25/14 12:51:00.422 luup_log:103: VeraAlert:103:ExpandRecipients:Adding User Specified Profile:email-MSF <0x2b82b000>
50 06/25/14 12:51:00.422 luup_log:103: VeraAlert:103:SendAlert:Sending to:MSF-Note3 <0x2b82b000>
50 06/25/14 12:51:00.428 luup_log:103: VeraAlert:103:VeraAlertsSend:url:http://veraalertsexchange.appspot.com/SendAlert?msg=[timestamp}tusting%20testing&recipient=MyAndroidDeviceID <0x2b82b000>
50 06/25/14 12:51:00.773 luup_log:103: VeraAlert:103:VeraAlertsSend:Return:200 <0x2b82b000>
50 06/25/14 12:51:00.774 luup_log:103: VeraAlert:103:SendAlert:Sending to:email-MSF <0x2b82b000>
50 06/25/14 12:51:00.775 luup_log:103: VeraAlert:103:MailSend:Addr:{ [1] = MyUserName@gmail.com,[2] = ,[3] = “MyUserName@gmail.com” ,[4] = MyUserName@msn.com,[5] = ,[6] = “MyUserName@msn.com” ,} <0x2b82b000>
Attached log (personal ID info removed)
Anyone there?
Quick update:
It’s been working sporadically to the phone and after turning 2 step authentication OFF on gmail and changing the port to 465, it worked…twice. Right now however I’m getting nothing on either profiles.
I have the following in the log (names, id removed):
08 06/27/14 15:34:59.019 JobHandler_LuaUPnP::HandleActionRequest device: 103 service: urn:richardgreen:serviceId:VeraAlert1 action: SendAlert <0x2f413680>
08 06/27/14 15:34:59.020 JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=103 <0x2f413680>
08 06/27/14 15:34:59.020 JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:richardgreen:serviceId:VeraAlert1 <0x2f413680>
08 06/27/14 15:34:59.020 JobHandler_LuaUPnP::HandleActionRequest argument action=SendAlert <0x2f413680>
08 06/27/14 15:34:59.020 JobHandler_LuaUPnP::HandleActionRequest argument Message=hi <0x2f413680>
08 06/27/14 15:34:59.021 JobHandler_LuaUPnP::HandleActionRequest argument Recipients=MSF-Note3 SMTP-GMail <0x2f413680>
08 06/27/14 15:34:59.021 JobHandler_LuaUPnP::HandleActionRequest argument rand=0.5716494559872765 <0x2f413680>
50 06/27/14 15:34:59.027 luup_log:103: VeraAlert:103:SendAlert:Msg:hi <0x2b6df000>
50 06/27/14 15:34:59.028 luup_log:103: VeraAlert:103:ExpandRecipients:Checking:MSF-Note3 <0x2b6df000>
50 06/27/14 15:34:59.028 luup_log:103: VeraAlert:103:ExpandRecipients:Adding Requested Profile <0x2b6df000>
50 06/27/14 15:34:59.029 luup_log:103: VeraAlert:103:ExpandRecipients:Checking:SMTP-GMail <0x2b6df000>
50 06/27/14 15:34:59.029 luup_log:103: VeraAlert:103:ExpandRecipients:Adding Requested Profile <0x2b6df000>
50 06/27/14 15:34:59.030 luup_log:103: VeraAlert:103:SendAlert:Sending to:MSF-Note3 <0x2b6df000>
50 06/27/14 15:34:59.031 luup_log:103: VeraAlert:103:VeraAlertsSend:url:http://veraalertsexchange.appspot.com/SendAlert?msg=hi&recipient=REMOVED <50 06/27/14 15:35:14.043 luup_log:103: VeraAlert:103:VeraAlertsSend:Return:host not found <0x2b6df000>
50 06/27/14 15:35:14.044 luup_log:103: VeraAlert:103:SendAlert:Sending to:SMTP-GMail <0x2b6df000>
50 06/27/14 15:35:14.045 luup_log:103: VeraAlert:103:MailSend:Addr:{ [1] = REMOVED,[2] = ,[3] = “REMOVED” ,[4] = REMOVED.50 06/27/14 15:35:14.046 luup_log:103: VeraAlert:103:MailSend:msgt:{ [“body”] = { [1] = { [“body”] = hi,} ,} ,[“headers”] = { [“Recipient”] = ,[“subject”] 50 06/27/14 15:35:14.047 luup_log:103: VeraAlert:103:MailSend:Setup for SSL <0x2b6df000>
50 06/27/14 15:35:14.050 luup_log:103: VeraAlert:103:MailSend:Profile.Args:{ [1] = { [“Name”] = Subject,[“Value”] = Vera Notification!,} ,[2] = { [“Name”] 50 06/27/14 15:35:14.051 luup_log:103: VeraAlert:103:MailSend:smtpt:{ [“rcpt”] = ,[“user”] = REMOVED,[“create”] = function: 0x121d968,[“password”] 50 06/27/14 15:35:29.065 luup_log:103: VeraAlert:103:MailSend:host not found <0x2b6df000>
06 06/27/14 15:35:29.065 Device_Variable::m_szValue_set device: 103 service: urn:richardgreen:serviceId:VeraAlert1 variable: LastMsgSent was: 15:29:16 50 06/27/14 15:35:29.085 luup_log:103: VeraAlert:103:SendAlert:Memory:395391 <0x2b6df000>
04 06/27/14 15:35:29.086 <0x2b6df000>
The above indicates you have network connectivity problems. appspot.com is a Google server … I have never seen it down or access to it restricted.
You might check to see if you can visit http://veraalertsexchange.appspot.com from your browser. If you can’t, it could indicate a problem with either DNS (try using Google’s - 8.8.8.8) or outright network connectivity (try running a trace route to veraalertsexchange.appspot.com).
Incidentally, it’s 3:30am, I couldn’t sleep, so I was reading the forums and read the URL as “Vera Alert Sex Change”. I was wondering what in the hell that could be until I visited the site myself. :smiley:
Thanks both. I could hit app spot in the browser bit tracert failed. Will look at it again, Sunday.
If you can hit it in the browser, then everything is apparently working from a networking perspective. The traceroute could be blocked for reasons not relating to your internet setup.
I’d try to see if you get the same error again.
Ok - I left the system, touched nothing, went away for two days. Magic happened and it started working again and did so until today. Investigation revealed my trial had expired. So I coughed up enough for 4 profiles. All updated but no alerts. Soft reboot, no difference. Hard reboot…seems to have sorted if for now. Will continue to monitor…
When it works it’s brilliant…when it doesn’t I’m left scratching my head thinking what changed? If anyone wants to volunteer to coach me in debugging, I’d be pleased to accept :).
I have another question but it’s off topic so will start another thread (1 minute to write it, 4 minutes to validate I’m a human…)
Cheers…
Turn on debug in Vera Alerts Settings tab and attach the logs … The report is also useful for looking over your Alerts configuration for the entire system.
Thanks.
Here’s the latest failed log. Perhaps I see the pattern, here’s my hypothesis: If I put Picture(ID) into the message and VeraAlerts can’t grab the picture, will the VeraAlert fail? I’m surmising this is the case because there’s no other pattern I can establish. I have two different cameras (a Y-CAM and a Foscam clone) and both have become intermittent with Vera (I can get to them via their own admin pages). Here’s the offending log example with highlight on what I think is the problem line.
02 07/03/14 22:44:05.103 e[33;1mZW_Send_Data node 2 NO ROUTE (nil)e[0m <0x2c33b680>
04 07/03/14 22:44:05.253 <0x2bf3b680>
06 07/03/14 22:44:29.502 Device_Variable::m_szValue_set device: 77 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: e[35;1mTrippede[0m was: 0 now: 1 #hooks: 2 upnp: 0 v:0xd17e88/NONE duplicate:0 <0x2bf3b680>
07 07/03/14 22:44:29.503 Event::Evaluate 7 Multi! scene MD Siren+Lights is false repeat 0/-1 <0x2bf3b680>
07 07/03/14 22:44:29.503 Event::Evaluate 13 H Play scene H Play is false repeat 0/-1 <0x2bf3b680>
06 07/03/14 22:44:29.503 Device_Variable::m_szValue_set device: 77 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: e[35;1mLastTripe[0m was: 1404421108 now: 1404423869 #hooks: 0 upnp: 0 v:0xd1d550/NONE duplicate:0 <0x2bf3b680>
06 07/03/14 22:44:38.652 Device_Variable::m_szValue_set device: 18 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: e[35;1mTrippede[0m was: 0 now: 1 #hooks: 4 upnp: 0 v:0xd17e88/NONE duplicate:0 <0x2bf3b680>
07 07/03/14 22:44:38.653 Event::Evaluate 1 Front Door scene MD Siren+Lights is false repeat 0/-1 <0x2bf3b680>
08 07/03/14 22:44:38.654 JobHandler_LuaUPnP::HandleActionRequest device: 103 service: urn:richardgreen:serviceId:VeraAlert1 action: e[36;1mDeviceNotificatione[0m <0x2bf3b680>
08 07/03/14 22:44:38.654 JobHandler_LuaUPnP::HandleActionRequest argument DeviceID=18 <0x2bf3b680>
08 07/03/14 22:44:38.654 JobHandler_LuaUPnP::HandleActionRequest argument Description=%20Front%20Door%20is%20tripped <0x2bf3b680>
08 07/03/14 22:44:38.655 JobHandler_LuaUPnP::HandleActionRequest argument Name=Boys%20Home%21 <0x2bf3b680>
08 07/03/14 22:44:38.655 JobHandler_LuaUPnP::HandleActionRequest argument Service=urn:micasaverde-com:serviceId:SecuritySensor1 <0x2bf3b680>
08 07/03/14 22:44:38.655 JobHandler_LuaUPnP::HandleActionRequest argument Variables=Tripped <0x2bf3b680>
08 07/03/14 22:44:38.655 JobHandler_LuaUPnP::HandleActionRequest argument Msg=Front%20Door%20Opened%20%7BPicture%2872%29%7D%20%7BPicture%2816%29%7D <0x2bf3b680>
08 07/03/14 22:44:38.656 JobHandler_LuaUPnP::HandleActionRequest argument SceneID=56 <0x2bf3b680>
08 07/03/14 22:44:38.656 JobHandler_LuaUPnP::HandleActionRequest argument Recipients=USER%20USER2 <0x2bf3b680>
07 07/03/14 22:44:38.658 Event::Evaluate 15 Boys Home! scene Boys Home is true users:148056,214901 allow:1 <0x2bf3b680>
08 07/03/14 22:44:38.658 Scene::RunScene running 56 Boys Home <0x2bf3b680>
08 07/03/14 22:44:38.658 JobHandler_LuaUPnP::HandleActionRequest device: 18 service: urn:micasaverde-com:serviceId:SecuritySensor1 action: e[36;1mSetArmede[0m <0x2bf3b680>
08 07/03/14 22:44:38.658 JobHandler_LuaUPnP::HandleActionRequest argument newArmedValue=0 <0x2bf3b680>
06 07/03/14 22:44:38.659 Device_Variable::m_szValue_set device: 18 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: e[35;1mArmede[0m was: 0 now: 0 #hooks: 4 upnp: 0 v:0xd1db68/NONE duplicate:1 <0x2bf3b680>
06 07/03/14 22:44:38.660 Device_Variable::m_szValue_set device: 18 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: e[35;1mLastTripe[0m was: 1404413987 now: 1404423878 #hooks: 0 upnp: 0 v:0xd1d550/NONE duplicate:0 <0x2bf3b680>
50 07/03/14 22:44:38.669 luup_log:103: VeraAlert:103:SendAlert:Msg:Front Door Opened {Picture(72)} {Picture(16)} <0x2b808000>
50 07/03/14 22:44:38.693 luup_log:103: VeraAlert:103:WebGetInfo:http://localhost:3480/data_request?id=request_image&cam=72 <0x2b808000>
06 07/03/14 22:44:38.722 Device_Variable::m_szValue_set device: 77 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: e[35;1mTrippede[0m was: 1 now: 0 #hooks: 2 upnp: 0 v:0xd17e88/NONE duplicate:0 <0x2bf3b680>
07 07/03/14 22:44:38.723 Event::Evaluate 7 Multi! scene MD Siren+Lights is false repeat 0/-1 <0x2bf3b680>
07 07/03/14 22:44:38.723 Event::Evaluate 13 H Play scene H Play is false repeat 0/-1 <0x2bf3b680>
06 07/03/14 22:44:38.724 Device_Variable::m_szValue_set device: 77 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: e[35;1mLastTripe[0m was: 1404423869 now: 1404423878 #hooks: 0 upnp: 0 v:0xd1d550/NONE duplicate:0 <0x2bf3b680>
50 07/03/14 22:44:39.839 luup_log:103: VeraAlert:103:WebGetInfo:Code:200 Size:48610 <0x2b808000>
50 07/03/14 22:44:39.896 luup_log:103: VeraAlert:103:WebGetInfo:http://localhost:3480/data_request?id=request_image&cam=16 <0x2b808000>
06 07/03/14 22:44:42.226 RAServerSync::SendAlert ID 2147483647,PK_Alert:USER1 sync 0x114d740 for https://cms1.mios.com/alert?PK_AccessPoint=REMOVED&HW_Key=REMOVED&DeviceID=18&LocalDate=2014-07-03%2022:44:38&LocalTimestamp=1404423878&AlertType=3&SourceType=3&Argument=15&Format=&Code=Tripped&Value=1&Description=Boys%20Home!&Users=148056%2C214901 <0x2c13b680>
06 07/03/14 22:44:42.372 Device_Variable::m_szValue_set device: 18 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: e[35;1mTrippede[0m was: 1 now: 0 #hooks: 4 upnp: 0 v:0xd17e88/NONE duplicate:0 <0x2bf3b680>
07 07/03/14 22:44:42.373 Event::Evaluate 1 Front Door scene MD Siren+Lights is false repeat 0/-1 <0x2bf3b680>
07 07/03/14 22:44:42.373 Event::Evaluate 15 Boys Home! scene Boys Home is false repeat 0/-1 <0x2bf3b680>
06 07/03/14 22:44:42.373 Device_Variable::m_szValue_set device: 18 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: e[35;1mLastTripe[0m was: 1404423878 now: 1404423882 #hooks: 0 upnp: 0 v:0xd1d550/NONE duplicate:0 <0x2bf3b680>
[glow=red,2,300]01 07/03/14 22:44:44.904 e[31;1mLuaInterface::CallFunction_Job device 103 function SVeraAlert_VeraAlert1_DeviceNotification_job failed [string “module(“L_VeraAlert”, package.seeall)…”]:127: bad argument #1 to ‘len’ (string expected, got nil)e[0m <0x2b808000>[/glow]
01 07/03/14 22:44:44.904 e[31;1mLua_Job::Run job#26 : dev:103 (0x11792d8) P:50 S:0 failede[0m <0x2b808000>
04 07/03/14 22:44:44.905 <0x2b808000>
02 07/03/14 22:44:44.906 e[33;1mJobHandler::PurgeCompletedJobs purge job#26 : dev:103 (0x11792d8) P:50 S:2 status 2e[0m <0x2b808000>
01 07/03/14 22:45:00.102 e[31;1mFileUtils::ReadURL 28/resp:0 size 0 http://192.168.1.149:4292/snapshot.cgie[0m <0x2c13b680>
01 07/03/14 22:45:00.103 e[31;1mIPCamera::ArchiveVideoFrame Cannot get frame for 16e[0m <0x2c13b680>
06 07/03/14 22:45:03.272 Device_Variable::m_szValue
Your camera returned an error instead of a picture.
Why does that make the whole alert fail? The event is still valid. Feature request to persist the alert even if a message component is missing.
I will have to look at some exception handling in that case.
I too have some notifications missing.
I’m on vacation right now so I only have internet connection in the hotel. As long as I have connectivity everthing is fine, notifications are beeing pushed to 3 different devices instantly.
When I have been off the net for a couple of hours and then regain my connection there are obviously some notifictions missing (e.g. the cat sitter leaves the house without entering). Shouldn’t messages be delivered regardless of how long the period of time between the last push and the actual time is? Vera alerts is configured to keep all messages.
I think Google has a limit of the number it will buffer if there is mo response. But it is not a small number.
50 notifications were delivered with maybe 5 missing in between. This is realy important to me. If I can’t rely on the list in vera alerts it defeats the purpose of the whole app.
