Not able to change hue color from vera
so for some reason in the update hue devices are not able to change color from the vera device … it works in altui but not UI7
found the problem from althe4 the SetColorRGB= 0,255,77 (turns the light green)
from UI7 it is sent as SetColorRGB= R0,G255,B77 (so nothing executes)
its actually not sending anything from the main device on the vera page when you change the color
I have fixed this in v 1.47 on github
I support both format now
let me know
will test it
Any update on this? I still have this issue.
Seems to work OK for me in the Vera UI7 Web GUI.
I just tested changing colours of a Phillips Hue Led light strip and it worked and the colours changed OK.
works for me
Same
Either you use the wrong version or the problem is different
