HI:
I am having the same issue. None of my nodes have neighbours, I have Vera 2 with Z-wave 3.2 L:1
Here is my repair report:
11-10-03 2:07:14 report for HealNetwork. Successful: Y Updated net: N mr_only:1 Job ID: job#2238 :heal network auto (0x78fac0) P:50 S:5
=======NEIGHBOR NODE UPDATES=======
Node 4 Device 43 Living 2 neighbor nodes updated 0 times (incomplete 0 in a row 0), woke up 0 times configured: YES
Node 33 Device 119 Closet neighbor nodes updated 0 times (incomplete 0 in a row 0), woke up 0 times configured: YES
Node 36 Device 123 Terraza neighbor nodes updated 0 times (incomplete 0 in a row 0), woke up 0 times configured: YES
Node 39 Device 130 Term Salita_T1 neighbor nodes updated 0 times (incomplete 0 in a row 0), woke up 0 times configured: YES
Node 40 Device 134 _Home Energy Monitor neighbor nodes updated 0 times (incomplete 0 in a row 0), woke up 0 times configured: NO
Node 42 Device 152 Piscina neighbor nodes updated 0 times (incomplete 0 in a row 0), woke up 0 times configured: YES
Node 43 Device 217 Pieza Principal neighbor nodes updated 0 times (incomplete 0 in a row 0), woke up 0 times configured: YES
Node 44 Device 219 Pieza Principal 1 neighbor nodes updated 0 times (incomplete 0 in a row 0), woke up 0 times configured: YES
Node 46 Device 231 Escritorio 1 neighbor nodes updated 0 times (incomplete 0 in a row 0), woke up 0 times configured: YES
Node 47 Device 232 Salita 2 neighbor nodes updated 0 times (incomplete 0 in a row 0), woke up 0 times configured: YES
Node 48 Device 262 Baño Niños neighbor nodes updated 0 times (incomplete 0 in a row 0), woke up 0 times configured: YES
Node 49 Device 234 Pieza Niños neighbor nodes updated 0 times (incomplete 0 in a row 0), woke up 0 times configured: YES
Node 50 Device 235 Pieza 2 neighbor nodes updated 0 times (incomplete 0 in a row 0), woke up 0 times configured: YES
Node 51 Device 236 Entrada neighbor nodes updated 0 times (incomplete 0 in a row 0), woke up 0 times configured: YES
Node 52 Device 237 Baño Visitas neighbor nodes updated 0 times (incomplete 0 in a row 0), woke up 0 times configured: YES
Node 53 Device 238 Salita neighbor nodes updated 0 times (incomplete 0 in a row 0), woke up 0 times configured: YES
Node 54 Device 239 Lavadero neighbor nodes updated 0 times (incomplete 0 in a row 0), woke up 0 times configured: YES
Node 55 Device 240 Living neighbor nodes updated 0 times (incomplete 0 in a row 0), woke up 0 times configured: YES
Node 56 Device 264 Baño Ducha neighbor nodes updated 0 times (incomplete 0 in a row 0), woke up 0 times configured: YES
Node 57 Device 242 Baño Principal neighbor nodes updated 0 times (incomplete 0 in a row 0), woke up 0 times configured: YES
Node 58 Device 243 Baño ppal espejos neighbor nodes updated 0 times (incomplete 0 in a row 0), woke up 0 times configured: YES
Node 59 Device 266 Pieza Milu neighbor nodes updated 0 times (incomplete 0 in a row 0), woke up 0 times configured: YES
Node 60 Device 267 Pasillo Living neighbor nodes updated 0 times (incomplete 0 in a row 0), woke up 0 times configured: YES
Node 62 Device 279 Acceso neighbor nodes updated 0 times (incomplete 0 in a row 0), woke up 0 times configured: YES
Node 63 Device 280 Comedor neighbor nodes updated 0 times (incomplete 0 in a row 0), woke up 0 times configured: YES
=======STRESS TEST RESULT=======
=======NEIGHBOR NODE RESULT=======
Inversely:
=======EDGE NODE PROFILE=======
Node: 4
Edge node: 0 score: 106 route: 1->0.0.0.0->4 num hops: 0 Latency avg: 150 max: 235 success 5 of 10
Node: 33
Edge node: 0 score: 26 route: 1->0.0.0.0->33 num hops: 0 Latency avg: 211 max: 1273 success 10 of 10
Node: 36
Edge node: 0 score: 5 route: 1->0.0.0.0->36 num hops: 0 Latency avg: 100 max: 183 success 10 of 10
Node: 39
Edge node: 0 score: 48 route: 1->0.0.0.0->39 num hops: 0 Latency avg: 1190 max: 1199 success 10 of 10
Node: 40
Edge node: 33 score: 118 route: 1->33.0.0.0->40 num hops: 1 Latency avg: 1338 max: 2430 success 8 of 10
Edge node: 57 score: 188 route: 1->57.0.0.0->40 num hops: 1 Latency avg: 1368 max: 5398 success 7 of 10
Node: 42
Edge node: 0 score: 4 route: 1->0.0.0.0->42 num hops: 0 Latency avg: 102 max: 130 success 10 of 10
Node: 43
Edge node: 33 score: 8 route: 1->33.0.0.0->43 num hops: 1 Latency avg: 100 max: 112 success 10 of 10
Edge node: 44 score: 30 route: 1->44.0.0.0->43 num hops: 1 Latency avg: 97 max: 185 success 9 of 10
Edge node: 46 score: 10 route: 1->46.0.0.0->43 num hops: 1 Latency avg: 103 max: 191 success 10 of 10
Edge node: 49 score: 10 route: 1->49.0.0.0->43 num hops: 1 Latency avg: 98 max: 191 success 10 of 10
Edge node: 50 score: 50 route: 1->50.0.0.0->43 num hops: 1 Latency avg: 106 max: 191 success 8 of 10
Edge node: 52 score: 70 route: 1->52.0.0.0->43 num hops: 1 Latency avg: 104 max: 186 success 7 of 10
Edge node: 56 score: 15 route: 1->44.56.0.0->43 num hops: 2 Latency avg: 97 max: 181 success 10 of 10
Edge node: 57 score: 10 route: 1->57.0.0.0->43 num hops: 1 Latency avg: 98 max: 191 success 10 of 10
Edge node: 58 score: 172 route: 1->58.0.0.0->43 num hops: 1 Latency avg: 145 max: 290 success 2 of 10
Edge node: 62 score: 10 route: 1->62.0.0.0->43 num hops: 1 Latency avg: 98 max: 191 success 10 of 10
Node: 44
Edge node: 0 score: 5 route: 1->0.0.0.0->44 num hops: 0 Latency avg: 98 max: 189 success 10 of 10
Node: 46
Edge node: 0 score: 5 route: 1->0.0.0.0->46 num hops: 0 Latency avg: 97 max: 187 success 10 of 10
Node: 47
Edge node: 0 score: 3 route: 1->0.0.0.0->47 num hops: 0 Latency avg: 99 max: 105 success 10 of 10
Node: 49
Edge node: 0 score: 5 route: 1->0.0.0.0->49 num hops: 0 Latency avg: 97 max: 189 success 10 of 10
Node: 50
Edge node: 0 score: 5 route: 1->0.0.0.0->50 num hops: 0 Latency avg: 97 max: 187 success 10 of 10
Node: 51
Edge node: 0 score: 3 route: 1->0.0.0.0->51 num hops: 0 Latency avg: 100 max: 115 success 10 of 10
Node: 52
Edge node: 0 score: 5 route: 1->0.0.0.0->52 num hops: 0 Latency avg: 97 max: 187 success 10 of 10
Node: 53
Edge node: 0 score: 25 route: 1->0.0.0.0->53 num hops: 0 Latency avg: 202 max: 1228 success 10 of 10
Node: 54
Edge node: 0 score: 5 route: 1->0.0.0.0->54 num hops: 0 Latency avg: 97 max: 187 success 10 of 10
Node: 55
Edge node: 0 score: 4 route: 1->0.0.0.0->55 num hops: 0 Latency avg: 104 max: 149 success 10 of 10
Node: 56
Edge node: 33 score: 20 route: 1->33.0.0.0->56 num hops: 1 Latency avg: 103 max: 827 success 10 of 10
Edge node: 43 score: 15 route: 1->33.43.0.0->56 num hops: 2 Latency avg: 98 max: 191 success 10 of 10
Edge node: 44 score: 10 route: 1->44.0.0.0->56 num hops: 1 Latency avg: 98 max: 190 success 10 of 10
Edge node: 46 score: 130 route: 1->46.0.0.0->56 num hops: 1 Latency avg: 108 max: 227 success 4 of 10
Edge node: 49 score: 10 route: 1->49.0.0.0->56 num hops: 1 Latency avg: 98 max: 191 success 10 of 10
Edge node: 57 score: 96 route: 1->57.0.0.0->56 num hops: 1 Latency avg: 109 max: 560 success 6 of 10
Node: 57
Edge node: 0 score: 5 route: 1->0.0.0.0->57 num hops: 0 Latency avg: 98 max: 188 success 10 of 10
Node: 58
Edge node: 0 score: 49 route: 1->0.0.0.0->58 num hops: 0 Latency avg: 111 max: 466 success 8 of 10
Node: 59
Edge node: 0 score: 5 route: 1->0.0.0.0->59 num hops: 0 Latency avg: 97 max: 188 success 10 of 10
Node: 60
Edge node: 0 score: 5 route: 1->0.0.0.0->60 num hops: 0 Latency avg: 103 max: 188 success 10 of 10
Node: 62
Edge node: 0 score: 5 route: 1->0.0.0.0->62 num hops: 0 Latency avg: 97 max: 188 success 10 of 10
Node: 63
Edge node: 4 score: 116 route: 1->4.0.0.0->63 num hops: 1 Latency avg: 202 max: 413 success 5 of 10
Edge node: 36 score: 10 route: 1->36.0.0.0->63 num hops: 1 Latency avg: 98 max: 191 success 10 of 10
Edge node: 42 score: 10 route: 1->42.0.0.0->63 num hops: 1 Latency avg: 100 max: 190 success 10 of 10
Edge node: 46 score: 8 route: 1->46.0.0.0->63 num hops: 1 Latency avg: 95 max: 102 success 10 of 10
Edge node: 51 score: 10 route: 1->51.0.0.0->63 num hops: 1 Latency avg: 98 max: 191 success 10 of 10
Edge node: 54 score: 29 route: 1->54.0.0.0->63 num hops: 1 Latency avg: 109 max: 156 success 9 of 10
Edge node: 55 score: 24 route: 1->55.0.0.0->63 num hops: 1 Latency avg: 116 max: 1069 success 10 of 10
Edge node: 59 score: 51 route: 1->59.0.0.0->63 num hops: 1 Latency avg: 121 max: 222 success 8 of 10
Edge node: 62 score: 10 route: 1->62.0.0.0->63 num hops: 1 Latency avg: 98 max: 191 success 10 of 10
=======DETAILED LOG=======
