Hi all,
Sorry bit of a newbie question.
This is the first dimmer I’ve ever had installed, Fibaro Dimmer 2 (FGD212) running on my Vera3 firmware 1.7.760
I’ve got 4 x non-dimmable standard bulbs hooked up but will change to LED’s at some point.
Question 1: How do I make sure the Dimmer doesn’t try to dim these? Want to have On/Off functionality only is there a variable somewhere?
Question 2: I added this as a ‘Other ZWave Device’ and now I’ve got two ghost devices showing. How do I remove these or are they needed? See screenshot attached
Question 3: HELP, How do I turn it off? I switch the wall switch to the off position, nothing happens, then flick it to on and it dims to around 10%. I can’t turn it on and off like a normal light anymore without doing via the Vera :
