I’m trying to use a NodOn remote in PLEG for turning a light on and off plus dimming. But when creating a trigger I get the error message popup saying: Trigger Description error: TypeError: Cannot read property ‘value’ of undefined.
Now, there is a text field on the “How is the button pressed:” that I have left empty and tested a lot of numbers like 0-4, 10-13 and so on. But no matter what I do, I get the same error message.
Does anyone know what am I doing wrong and what is the expected value to enter?
Can you create a Scene trigger for this device ?
If Scene’s have the same problem then it may be a problem in the device configuration files.
If it can, then I have a bug reading the device configuration info …
Please send me the D_XXXX.json file for that device. (App → Develop → Luup Files)
You can find the specific file by going to the advanced tab for your device. It’s the device_json property.
I’m getting the same error message while trying to use PLEG with a GoControl WA00Z-1 device. The device buttons can be assigned to Vera scenes and the Scenes run as advertised without issue. However when trying to use the WA00Z-1 as a trigger within PLEG I get the trigger description error: rigger Description error: TypeError: Cannot read property ‘value’ of undefined.
Device Json says: D_CentralSceneController1.json
json and screenshot files attached.
Thanks in advance and any assistance would be appreciated.
I need some information to debug this …
For WallMote device (or any other device that you get this error on)
Open the Advanced tab for that device.
On the params page what is the value for the:
device_json paramrameter ?
Also when you try to create the trigger … describe what pull down selections you make. (The options for the pull down come from the device_json file)
I should be able to see what the problem is.
The value for device_json is: D_CSC_2ButtonsTapHold.json
I attached the trigger screen earlier, attaching it again. Is this what you need? There are 4 options under “Which action” (tap/hold of buttons 1/2) but I get the error on all 4 of them.
The drop down list for this trigger has values:
Tap Button 1
Tap Button 2
Hold Button 1
Hold Button 2
This is the first time some one reported a problem where the drop down values have a “Space” in the name
Usually they are things like:
On
Off
Heat
Cool
I do have a problem with this … I release a fix soon …
I have a fix if you can test (I tested to make sure it did not break anything)
Email me at schaefer@rts-services.com … and I will send you the file … It’s to big to attach here.
