I have added Vera (MIOS) palette to Node Red, but I am unable to get connected to my Vera (I have local access enabled). I have error: Flows stopped due to missing node types - server. I have entered my LAN IP of Vera and port left as it is: 3480. Any help?
OK, now it is connected. But I want for example get the humidity value from humidity sensor in bathroom. When I specify Room:Sensor:Variable in Item of Mios-In node, nothing happens… How can I get the value from Vera sensor?
Had been able to move all my PLEGs to NR, I basically use Vera only as a Z-Wave gateway to my Z-Wave devices now. Everything moved to RPi 4 via NR or Homebridge and to HK, uninstalled most of the plugins on my Vera (free memory rocketed to sky levels:-).
It is mayby sad (5 year with Vera without any major flaw), but current state with Ezlo/Vera development made my decision to become platform independed and go with RPi Homebridge/NodeRed or native HomeKit way…
I’ve just moved all my Pleg’s to the new Multi System Reactor running on a Pi. I think that is much easier to use than Node Red for logic rules.
But I don’t know Node Red much, I’ve used it a bit for some things, manly for sending announcements from Vera to my Google Home speakers and also for some Tuya / Ewelink device integration, which to be honest I found to be unreliable.
I’ve been trying the different plugins for X10 control. I have used the mochad plugin and that works very well, you just need to have another server to run mochad on.
