I have attached a raw export of an entire event to this message, here is what I did.
Wait for “Ready to Arm”
Set to “ARM STAY”
Waited for countdown
Walked in front of motion sensor to trigger it (Zone 2) while system was armed.
Opened Entry Door (Zone 1) while system was armed
Waited a few seconds to disarm system during entry delay.
Disarmed alarm
Closed Entry Door (Zone 1)
Reopened Entry Door (Zone 1)
Here are the highlights of the attached file.
Starting ad2usbgui build #2.0.6.22064
Example V1.0 initialized
keypad V1.0 initialized ()
Waiting for communication to AD2USB to open
VER:ffffffff,V2.2a.6,TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;LR;KE;MK;CB
Communicaiton to AD2USB established
Trying to make sure we are not in config mode sending rn A Bunch!
Sending ‘rn’ to check if in config mode.
The AD2USB not in config mode. Continuing to initialize.
Sending ‘V’ command to the AD2USB
Found Version String
Sending ‘C’ command to the AD2USB
!CONFIG>ADDRESS=18&CONFIGBITS=ff00&LRR=N&EXP=YYNNN&REL=YYYY&MASK=ffffffff&DEDUPLICATE=N
Found and saving Config String
Sending ‘rn’ command to the AD2USB
[1000000100000000----],008,[f70600071008001c08020000000000],"DISARMED Ready to Arm "
!Sending.done
[0011030100000000----],060,[f70600071060038008020000000000],“ARMED STAYMay Exit Now 60”
[0010000100000000----],008,[f70600071008008c08020000000000],"ARMED STAY "
!REL:12,02,01
!EX> Item List changed name: 12 id: 412
!REL:12,02,01
[0011050100000000----],008,[f70600071008058c08020000000000],"DISARM SYSTEM or alarm occurs "
!REL:12,02,00
[0000010100000000----],008,[f70600071008010c08020000000000],“DISARMEDHit * for faults”
[0001000100000000----],001,[f70600071001000008020000000000],"FAULT 01 FRONT GARAGE ENTRY "
!REL:12,01,00
[1001000100000000----],008,[f70600071008001c08020000000000],"DISARMED Ready to Arm "
!REL:12,01,01
