Just moved into an old home, and the light switches don’t have a neutral line.
This is a very out-there idea, but figured I’d run it by you all and see what you think.
What if I just took the line and load and connected them in the Jbox, and then installed a Z-wave lightbulb. That way the bulb is always receiving power, and can be turned on/off via Vera.
On top of that, is there a way to install a switch into that wall, give it power (via batteries or from the wiring) and connect it to Vera so that when the button is pressed it sends a Z-wave signal (NOT a change in the actual power line) that directs the lightbulb to turn on/off.
Do you think this is possible? I searched in the forum, but couldn’t find much on this.
There are Z-Wave micro switches you could install at the light location that would allow you to use standard bulbs but still adhere to your idea. Leave the standard switch in place is also an option to switch power to the micro switch on or off as sort of a backup.
That will work, might frustrate others who try to use the switch![/quote]
Haha I’m thinking of putting in z-wave bulb, connecting line & load within the wall, then removing regular switch and putting a scene controller instead
Caseta Wireless lighting can be used in 2 wire applications. If you want to connect them to Vera the cheapest way is via a Wink hub+plug in.
Also Cooper makes a battery powered switch that can control z-wave bulbs via direct association, however they cannot be installed over an existing jbox. They just stick on the wall. So you would have to put a blank plate over the jbox then put the Cooper next to it or something (not the best looking option)
This right here. The switched hot that you have will throw the relay in an enerwave single or dual relay z-wave device and things will act as normal for most people. The switch will act like a 3 way switch where it will change the state of the device no matter if the switch is up or down. this set-up is what these relays were designed for as far as i know.
Use a Z-wave switch that does not need a neutral and use an incandescent bulb
(You can also play with a hidden low wattage incandescent bulb in parallel with CFL or LED lamp)
The incandescent provides a high resistance circuit for the Z-Wave switch to work even though the light is out.
Modify the circuit.
Modify the “LOAD” wire at the switch and the fixture … Connect it to the Ground at the Fixture. … Make sure you mark this wire … i.e. wrap it with white tape on both sides.
Then you can continue to use the Z-Wave switch at the fixture … and you will have power for a Z-Wave scene controller.
I would have done this with a Z-Wave module at the fixture … which would have provided more light options at the fixture.
[/quote]
RTS, Are you saying that you can use a “normal” z-wave relay in a no neutral scenario or have I read this wrong?
edit: If you are, can you post a schematic of what you have in mind?
RTS, Are you saying that you can use a "normal" z-wave relay in a no neutral scenario or have I read this wrong?
NO, the original Z-Wave incandescent light switches did NOT have or require a neutral. But they required a bulb that was resistive, i.e. even when it was off a small leakage current, not enough to turn the light on, would supply power for the Z-Wave device.
LED and CFLs bulbs will not work for this, but you could use these if you put a 10 w (refrigerator/microwave) bulb in parallel with these bulbs.
