No local access
So this is a new one for me, I can only log in remotely and all my cams are down. When I log in locally I get a screen that I’ve never seen before that says “MiOS Administration main page”. When I click the “main page” link I then get a failed to open page error. I checked my router and made sure vera was showing up and did a copy/paste into the browser of the local ip and still nothing. Any thoughts on this?
Hi mbairhead,
The “MiOS Administration main page” page (white text on black screen) always appears for me, quickly redirecting to the regular UI4 screen. You can bypass this by going to the http://your-vera-ip-address/cmh/ URL (note cmh part) directly. Obviously, this should have happened automatically, but it might be instructive to do it manually and see what the error message is.
I don’t suppose you can ssh into your vera and scope out some of the logs?
