Just bought a panasonic BL-C111 cam. Set it up with vera as an ip camera. When I access the camera, I can move it right/left/up/down but no image is showing on the site ( read broken image ) ?
Looking at the generated html I see the following uri being used.
Is this wrong ?
Also, this cam is supposed to have a build in motion sensor. I wanted to turn a light on when the cam sensor is tripped. So I went to the event page to try to setup an event but my cam device does not show up when I select ‘A sensor is tripped’ ? ie select device is not getting populated with my cam. What am I missing ?
Thanks !!
