Alrighty how do I explain this.
So I have a setting on my Fibaro relays that basically turns them off after a certain amount of time. For the passageway this is quite short as I only need them on for a really short duration.
The trouble is, yes the Vera does react very quickly to detecting things - but its speed with setting things is abysmal. For example if I turn a light on manually Vera instantly knows this - but if I have Vera turn a light on it can sit there for quite a while, often retrying, sometimes a couple of times, and then succeeds. The dumb thing is that what it wants to do happens instantly (e.g. turn on a light) but it takes a long time to realise this worked - yet it gets the feedback instantly when I do it myself?
Anyways setting up a scene caused a total and utter meltdown. The scene was triggered, Vera tried to turn on the light (which it did but Vera didn’t know), she sat there for ages, she retried, she sat there, but then the relay auto turned off, and then Vera retried a second time… so the light went on, it went off, it went on… then of course the sensor also timed out and turned off. Seems simple, but when I walked down that passage several times the whole system ended up going into total and utter meltdown.
I’ve had to turn off the option in the Fibaros to auto turn off. This was painful as all the devices went into non-responsive state, even after I power cycled EVERYTHING… so after all the hell I’ve had with all this Z-Wave compatibility, with Vera, the whole thing, I was ready to take the thing into the street and belt it with a hammer. I’m really very frustrated with this whole thing… right from the start when the Vera bricked itself straight out the box. Anyways I instead walked away and put my daughters to bed. Came back half hour later and everything had finally configured and gone back to normal.
So I’v now re-set up the scene. The response time is shocking - well sometimes it is almost instant, sometimes there’s a huge delay, and likewise with turning it off - but it works. It’s unusable - passage is only a few metres so all this crap happens after you have already traversed the darkness, but it works.
Now I know what you’re thinking - you have reception problems causing these Z-wave comms issues. Negative - this particular relay is a whopping 3m from the Vera. Nothing in-between. The other relays are about 4m from the Vera, one wall between those. And don’t forget if I flip the light switch manually, over and over and over and over, the Vera INSTANTLY acknowledges this… every time. The problem is only when the Vera instructs this - the action occurs instantly but Vera struggles to get feedback.
Completely off topic, but hopefully someone might have an answer why that is. I have polling off, it seemed a waste of precious Z-Wave traffic when I strictly use Z-Wave Plus devices which are meant to provide instant feedback without polling, but maybe I need to turn that on… but then again to solve this issue it would need to be polling every few seconds which is a really really bad idea.
In any case this sensor is useless anyway as it only has a range of 3m and, more importantly, a shockingly poor angle of vision… so it doesn’t even see you until you’re almost under it. Compared to the 20+ year old security PIRs I have about the house which can see you from opposite end of the house, seriously. I think I’m going to have to give up on the MultiSensor and do it myself via the Z-UNO.
