So, control4 released an app for this. while rummaging around trying to decode some of the API, I found that our friends at smart things have figured it out…
check out:
specifically, the code for ST things updated is here: [url=https://github.com/nathan-curtis/SmartThingsPublic/blob/master/smartapps/trentfoley/nexia-thermostat-manager.src/nexia-thermostat-manager.groovy]https://github.com/nathan-curtis/SmartThingsPublic/blob/master/smartapps/trentfoley/nexia-thermostat-manager.src/nexia-thermostat-manager.groovy[/url]
Kudos and thanks to nathan curtis…
so the question is (I am not new to coding but still learning how things work in vera) can anyone run with the code to create a bridge/control app through the api for our Veras???
It appears the hardest part has already been done…
