Hello all,
We continue with our posts with newly integrated devices on Ezlo Platform.
Here you can see the newly integrated Zigbee devices :
| Manufacturer | Device Type | Model Number |
| LUX | KONOz | 180428000059 |
| Aqara | Water Leak Sensor | SJCGQ11LM |
| Sylvania | SMART+ Soft White | 74389 |
| Heiman | Smart Wireless Siren Heiman HS2WD | HS2WD-E |
| Sengled | Smart Led Multicolor | E21-N1EA |
| EUROTRONIC | Energy Saving Controller with Radio Standard | 700045 |
| Sylvania | Adjustable RT 5/6 Recessed Lighting Kit | 73742 |
| Sylvania | RGBW Full Color and Tunable White Starter Kit | â73661 |
| Sylvania | Bulb, Color Changing and Dimmable A19 LED Bulb,60 Watt Equivalent(2pack) | â73859 |
| Philips | Portable Dimmable LED Light Table Lamp | â7602031 |
| Sengled | Smart Led Strip Lights 16.4ft | B089KHKGZW / 19010207 |
| innr | Smart Bulb Color A19 | âAE 280C-2 |
| AICase | Smart Light Bulb | âE0755 |
| Enbrighten GE | Outdoor Smart Switch | ZB4201 |
| Enbrighten GE | Plug-in Smart Switch | ZB4103 |
| Enbrighten GE | Plug-in Smart Dimmer | ZB3103 |
| Enbrighten GE | In-Wall Smart Dimmer | ZB3004 |
| Enbrighten GE | In-Wall Smart Switch | ZB4004 |
| Enbrighten GE | In-Wall Smart Dimmer | ZB3003 |
| Enbrighten GE | In-Wall Tamper-Resistant Smart Outlet | ZB1001 |
| Enbrighten GE | In-Wall Tamper-Resistant Smart Outlet Prise intelligente inviolable | 43132 ver 3.0/ZB1002 |
| Centralite | Micro Motion Sensor | 3328-C |
| AduroSmart ERIA | Door Window Sensor | 81822 |
| DOGAIN | Smart Plug | Smart Plug |
| Seedan | Smart Plug, Smart Outlet | Smart Plug, Smart Outlet |
| THIRDREALITY | Motion Sensor | 3RMS16BZ |
| Sonoff | Smart Plug | S31 Lite zb |
| 3A | Smart Strip Light Controller | 3A12S-15 |
| 3A | Smart Light Dimmer Switch | HGZB-02A+ |
Here you can see the newly integrated Z-Wave devices :
| Manufacturer | Model Number | Device Type |
| Fibaro | Double switch 2 | FGS-223 us v3.3 |
| Yale | yale assure lock sl | âYRD256-ZW2-619 |
| UltraPro | In-Wall Dimmer | 39351 |
| Jasco | Dimmer Switch | 45742-1 |
| Philia | Siren | PSE02-2B |
| Fortrezz | Flood and Temperature Sensor | FTS05us |
| Yale | Lock Keypad Deadbolt in Satin Nickel | YRD110-ZW-619 |
| Somfy | Channel Z-Wave to RTS Plug-in Interface Wall Module | ZRTSI RTS 16 |
| Enerwave | Z-Wave Plus Ceiling Sensor ZWN-BPC-PLUS, White | ZWN-BPC-PLUS |
| Neo | Z-Wave Plus Siren Alarm with Strobe alerts | NAS-AB02ZU-G |
| RGBgenie | RGBW LED Driver Dimmer and Repeater, Constant Voltage Strip Light Controller with built-in Power Supply. | ZV-1008 |
| Delaney | Smart Home Automation Z-Wave Gas/Water Auto Shutoff Valve for Pipes up to 1 1/2 Compatible Smartthings Vera | GR-105N |
| RGBgenie | Micro Controller and Lamp Module - Single Channel Trailing Edge Dimmer with Momentary Switch Input | ZW-4001 |
| UltraPro | Z-Wave Plus Smart Light Switch, in-Wall Toggle | 39354 |
| Ring | Ring Alarm Flood and Freeze Sensor | 4SF1S8-0EN0 |
| Fortrezz | Wireless Z-Wave Multi-Input/Output Dry Contact Bridge MIMOLite | ZC08-16040002 |
| Aeotec | Aeotec by Aeon Labs ZW095 ZW095-A Home Energy Meter Gen5, Small, White | ZW095 |
| Enerwave | Hidden Smart Switch Wireless Remote Control to Lights and Ceiling Fans | ZWN-RSM1-PLUS |
| Fortrezz | FortrezZ Z-WavePlus MiMO2+ Interface Module | MIMO2US |
| Aeotec | Aeotec Nano Dimmer lighting controlle | ZW111-A |
| Aeotec | Aeotec Nano Shutter, Z-Wave Plus Controller Automatic Blinds Curtains, Shades, Gates, Smart Blinds Invisible Installation | ZW141-A |
| Leviton | Decora Smart Tamper-Resistant Outlet | ZW15R-1BW |
| Enbrighten GE | Smart Outdoor Switch, 1-Outlet Plug-In (2nd Gen.) | ZW4203 |
| Honeywell | Tamper Resistant Smart Outlet | Z5OUTLET |
| Aeotec | Indoor Siren 6 | ZW164-A |
| Enbrighten GE | In-Wall Add-On Switch | ZW2003 |
| Enbrighten GE | In-Wall Add-On Switch | AS2005 |
| NEO Coolcam | Motion Sensor Detector Home Automation | NAS-PD02ZU |
| Aeotec | Wall Swipe | ZW158-Z |
| Aeotec | Nano Switch | ZW139-A |
| Eaton | Universal Smart Dimmer | RF9640-N |
| Ring | Alarm Range Extender | Range Extender |
| Ring | Alarm Panic Button | Panic Button |
| Qubino | Z-Wave Plus RGBW Controller ZMNHWD3 for 12-24V LED Strips and Light Bulbs | ZMNHWD3 |
| Schlage | Smart deadbolt | BE469ZP V CAM 619 |
| Kwikset | Smart Code touchpad electronic deadbolt | 912 |
| Aeotec | Dual Nano Switch | ZW132-A |
| Trane | Temp/Hum Sensor | ZSENS930AW00MA |
| Eaton | Wireless Switch | RF9617DW |
| STELPRO | Electronic termostat | STZW402+ |
| GoControl | Smart Retrofit Lighting Kit with LED Bulb | LB65R6Z-1 |
| Zooz | RGBW dimmer | Zen31 |
| Neo | Z-Wave Plus Smart Light Switch 1 Gang 2 Switches in-Wall Smart Switch Touch Panel Touch Sensitive | 39122200 |
| Zipato | Micromodul Single Switch | PH-PAN03.US |
| heatit | Z-Push Button 4 | 45 126 82 |
| heatit | Z-Push Button 8 | 45 125 81 |
| Honeywell | Z-WAVE Enabled 7-DAY Programmable Thermostat with Wire saver | TH8320ZW |
| GoControl | Z-Wave Battery-Powered Smart Thermostat | GC-TBZ48 |
| TRANE | 14942771 Thermostat, Z-Wave, Works with Alexa | TZEMT524AA21MA |
| Enbrighten GE | 40-Amp Indoor/Outdoor Metal Box Smart Switch | ZW4007/ZW4004 |
| Fibaro | Smart Implant | FGBS-222 |
| Sensative | Drips 700 US | RC10 |
| heatit | Z-Din 616 | 45 125 61 |
| Sensative | Guard 700 Us | RC10 |
| heatit | Z-Water | 45 124 75 |
| Aeotec | Heavy Duty Smart Switch Gen5 | ZW-07A |
| Evalogik | In-Wall Smart Dimmer Switch | ZW31S |
| Haozee | Door/Window sensor with temperature and humidity | B0923ZFHB2 |
| Evalogik | Smart Plug | ZW39 |
| Enbrighten GE | Smart Dimmer | 28166/ZW3104 |
| Fibaro | Motion Sensor | FGMS-001 ZW5 v3.3 |
| Enbrighten GE | Flood/Freeze Sensor | 52247/ZW6309 |
| Zooz | Remote Switch | ZEN34 |
| Enbrighten GE | Hub/Panel Remote | 53831/ZW5314 |
| Aeotec | Smart Switch 7 | ZWA023-A |
| Evalogik | Smart Plug Outdoor | ZW96 |
| Yale | Locks & Hardware | YRD156-ZW2-619 |
| Enbrighten GE | Smart Motion Sensor | 52251/ZW6307 |
| Enbrighten GE | In-Wall Smart Switch | 46562 |
| Enbrighten GE | Hub/Panel Remote | 53829/ZW5313 |
| Minoston | Smart Dimmer Switch | MS11ZS |
| Yale | Smart Module | AYR202-ZWV-USA |
| Heltun | Fan Coil Thermostat | HE-FT01 |
| Schlage | Connected Keypad Lever | FE599NX Cam 716 ACC |
| Heltun | Heat Thermostat | HE-HT01 |
| Yale | Assure Touchscreen with Cambridge Knob-Works with Ring Alarm | B-YRD226-ZW-CM-0BP |
| Heltun | Advanced Programmable Z-Wave Touch Panel Switch | HE-TPS05 |
| 2GIG | Radio Thermostat | CT-30 |
| Yale | Locks & Hardware 700 | YRD216-ZW3-619 |
For the full list of devices that are integrated with Ezlo platform you can always check
-Z-Wave Full List
-Zigbee Full List
-2 Gig Full List
We keep all of these pages up to date with whole lists ![]()
