Hello all,
We continue with our posts with newly integrated devices on Ezlo Platform.
Here you can see the newly integrated Zigbee devices :
| Manufacturer | Device Type | Model Number |
| Sengled | Smart LED | E12-N1E |
| Sengled | Smart Plug with energy tracker | E1C-NB7 |
| LEOMOCA | Smart Light Dimmers Switches Module | LE-SWDM-01/QS-Zigbee-D02-TRIAC-LN |
| eSupport | Smart Plug | SA-003-US-Zigbee |
| Sonoff | Wireless Door/Windiw Sensor | SNZB-04 |
| Sonoff | Smart Switch | ZBMINI |
| Sonoff | Smart Switch | BasicZBR3 |
| LEOMOCA | Smart Light Switch Module | LE-SWMK-O1 |
| Sonoff | Sonoff | SNZB-01 |
| Sylvania | SMART+ | 73740 |
| GLEDOPTO | 4W E12Pro ZigBee RGBCCT Candelabra LED Candle Light Bulb 2000K~6500K | GL-B-001P |
| GLEDOPTO | 4W E12 ZigBee RGBCCT Candelabra LED Candle Light Bulb 2000K~6500K | GL-B-001Z |
| GLEDOPTO | LED PRO Flood Light 10W 700LM 2700K~6500K Light IP65 Waterproof | RGBCCT AC100-240V |
| Yale | Assure Lock SL Smart KeyFree Touchscreen Keypad Deadbolt | YRD256-HA2-0BP |
| Sengled | Smart LED Candle Bulb | E1F-N5E |
| Sengled | Sengled Smart LED Filament Candle | E1F-N9G |
| Philips | White & Color E12 LED Candle Light Bulb | 556968 |
| Philips | White Ambiance E12 LED Candle Light Bulb | 556976 |
| Philips | Dusk-to-Dawn Outdoor Motion Sensor for Smart Home | 541730 |
| Philips | White Outdoor PAR38 13W Smart Bulbs | 476812 |
| Philips | Smart Outdoor Lightstrip, 2m/7ft | 555904 |
| AduroSmart ERIA | Dimmable Soft White LED Smart Bulb BR30 | 81815 |
| Philips | Outdoor White & Color Ambiance Smart Floodlight | 1743530V7 |
| Philips | Outdoor White & Color Wall Lantern, Up | 1743930V7 |
| Philips | Gradient LightStrip 55" | 560409 |
Here you can see the newly integrated Z-Wave devices :
| WaterCop | Electric Actuator Motor | ZWACT |
| Dome | Water Main Shut-off | DMWV1 |
| NEO Coolcam | Repeater | NAS-RP01 |
| Honeywell | T5 Touchscreen Programmable Thermostat | RCHT8600ZW |
| Kwikset | Modern Contemporary Touchscreen Smart Lock Deadbolt Featuring SmartKey Security | 99160-017 |
| Qubino | Mini Dimmer | ZMNHHD3 |
| Qubino | Flush Shutter DC | ZMNHOD3 |
| Qubino | Flush Dimmer | ZMNHVD3 |
| Qubino | Flush On/Off Thermostat 2 | ZMNKID3 |
| Qubino | Smart Meter | ZMNHTD1 |
| Heiman | Smoke Sensor | HS1SA-Z |
| Aeotec | Door/Window Sensor 7 Pro | ZWA012-A |
| Leviton | Vizia RF Plus Plug-In Dimmer | VRP15-1LW |
| Aeon | 4-in-1 sensor | |
| Honeywell | T6 Pro Series Z-Wave Stat Thermostat | TH6320ZW2003 |
| Fibaro | FIBARO RGBW Controller 2 Z-Wave Plus LED Strips Regulator | FGRGBW-442 |
| Kwikset | Obsidian Touchscreen Electronic Deadbolt ZW500 | 99540-001 |
| Kwikset | SmartCode914 Touchpad Electronic Deadbolt | 99140-019 |
| illumino | Wall Switch | ZWA038-A |
| illumino | Dimmer Switch | ZWA037-A |
| MCO HOME | Touch panel switch | MH-S512 |
| Zooz | S2 Dimmer 700 series | ZEN77 |
For the full list of devices that are integrated with Ezlo platform you can always check
-Z-Wave Full List
-Zigbee Full List
-2 Gig Full List
We keep all of these pages up to date with whole lists
