I have just installed Vera and have one device installed a WDTC20 thermostat.
Easy to install and works great (well I only installed it last night).
I started setting up some scenes to control the thermostat.
I’ve created a scene with 2 timer events, but I’d like each of them to do something different (set different temps). Is this possible? It seems there is just one action for the scene, rather that one per timer event.
I’d like to do something different depending on the time of year (summer vs winter) is this possible?
for tips on creating a luup scene. It’ll take a little trial and error, and more digging to find the right commands, but in a luup scene you should be able to determine the month of the year and pick your settings accordingly.
Hope this helps.
