OK…
I’m sorry to start a new thread, because I THINK everything I need to know is actually already on here somewhere, but after searching for days, I can’t get this all working, and I think it’s because some of the information I’m reading isn’t current, so I’m hoping someone can give me some idea of what I’m doing wrong with my AD2USB connection to Vera…
I have a VeraLite running the most current code. I have installed my AD2USB on my Vista20P panel, and it is configured to address 18, and I can successfully use PUTTY or the PERL based virtual keypad to see/monitor, and type into the alarm system successfully, so I ASSUME I’m good up to the USB connection into the alarm…
Now, before I go into what I do next, let me say that really all I would like to do is to be able to monitor when doors / windows are open and shut, and MAYBE later, arm or disarm the alarm, but for now, I’d be very happy if I could just use the state of the doors/windows in my scenes, so I could (for example) make a scene that says when a door is opened, and it’s night time, turn on the lights, so it can turn on the lights when I open the door…
As for how I’m getting there, this is what I’m doing, which isn’t working:
I plug the USB into the Vera, and load the AD2USB module on Vera’s webpage. I have seen some talk in forums about updating the USB driver, but I see a dev/ttyUSB0 and was able to configure my serial port with that device (see capture1.jpg). I was able to go into the AD2USB module, and tell it to create device, and it says it created “Ademco Vista Alarm Panel” device.
In the “Ademco Vista Alarm Panel” device, I assign it a room, and change the name to “Alarm Panel” because it says it can’t be more than 20 characters, then under Advanced / Variables, in the “NumPartitions”, I put 1, because I saw someone mention that in a thread…
Now, under devices / Apps, I see “Alarm Panel” but it says “Ademco Vista Plugin Can’t Detect Device” and in the header of the page, it says “Ademco Vista Plugin : No keypad assigned to partition 1.”… I will reboot the vera just for good measure…
After reboot, I have an “Ademco Vista Partition 1” device, but it has an error: “Can’t Detect Device”. I go into that device, and under advanced/variabled, I set the keypadAddresses to “16,18”. (I dont think I have a keypad 17, but when I set this up originally, I thought I did… Could THIS be the problem? Do the keypads have to be sequential? I dont think so, since it worked through the keypad emulator, but I mention in the interest of full disclosure!!)
So… Now, I’m stuck… It SEEMS like it should be working, and I see where I can enter zone names under the cheatsheet thing (although what those fields to the right mean are still a question to me!!) but it seems that it SHOULD NOT be giving me the errors I’m getting at this point… (Capture2.jpg)
Can ANYONE tell me where I’m going wrong??
Thanks so much in advance!! I’m a newbie at this whole vera thing, but very excited about the possibilities!!
-Steve
