Apologize if this has been answered before, but I’m just getting started with LUUP and Lua, so very newbie…
From my Lua script - I want to know if a Powermax PIR sensor is in “tripped” state.
I thought this was as easy as checking the “tripped” parameter on the sensor, but that doesn’t seem to work.
If I do something like:
local SENSOR = 8
local SES_SID = “urn:schemas-micasaverde-com:device:MotionSensor:1”
local tripped = luup.variable_get( SES_SID, “Tripped”, SENSOR)
It returns “(null)” both when it’s tripped and not tripped…
Just to follow up myself - tried to pull some other properties like “LastTrip” on some of the PIRs - but LUUP returns “(null)” regardless of which property I’m trying to fetch. I must be missing something very obvious ;D ???
