I also can’t figure out how to add my garage door openers to the controller via the Liftmaster MyQ app in Vera.
I see this in the myQ Set-up in Vera:
myQ authorization failed
Please Help.
Please Help.
I just went thru the same exact exercise.
It took 2 tries to get it working.
Installed the plug in once… fiddled with it… then deleted it and started over.
Installed a second time.
It took a few minutes for it to properly install and show up.
You also need to configure it.
Choose the brand, enter username (email address) and password details.
After about 3- 5minurtes… it all worked.
[quote=“cbaksa, post:2, topic:193076”]I just went thru the same exact exercise.
After about 3- 5minurtes… it all worked.[/quote]
Well I tried uninstall/reinstall and now [at least] I get a DIFFERENT message after entering the brand and my credentials in the set-up:
Username not configured. Password not configured
It’s been about 10 min. Should I keep waiting?
I had no problem configuring MyQ and VeraEdge, the addon installed on first attempt.
