Newbee to VeraEdge here. I just purchased a VeraEdge. Firmware 1.7.1707. I bought a Leviton DZS15 Switch at Home Depot as my first switch. It has the ZWave logo on the front. When I went to pair the device I did not see any Leviton devices in the supported Dimmers and Lights, so I used Other ZWave Device instead.
Afterward it now shows the device as an On/Off switch. The icon is a plug with an R in the center. On the iPhone Vera App it does not show up on the dashboard under my Shortcuts - No Lights Available shows up instead. So I am thinking there is a category of devices that show up as lights, and the DZS15 Other Device is not identified in that category. Other than this the switch turns on and off and gets updated in about a second or two. My questions are:
- Why doesn’t a common switch like the Leviton from Home Depot not get included in the supported devices?
- Is there some other supported light switch that I could use instead that would make this a light switch?
- Is there a way for me to tweek the configuration settings to make this work like a light switch and show up in the Lights category (if I am right about this)?
Thanks in advance.
