Please correct me if I am wrong here:
I was under the impression that the latest Z-Wave firmware upgrade was meant to correct a problem where the routing tables were not being updated properly when a device was moved?
Example:
I have a 3-in-1 that was working intermittently - located in an extension of my “mesh” about 150ft from the Vera in a different building. There are other non-battery devices in between, working reliably and within 50ft of each other.
Last night I excluded the 3-in-1 and then included it to solve the Variables problem, and today I ran the ADD program to test the network. The output shows the remote 3-in-1 trying to talk to the devices closest to the Vera (I brought the 3-in-1 to the Vera rather than vice versa) and not to the hard-wired devices within a few feet of itself.
I know a solution is to dongle the Vera and take it to the 3-in-1 located where it should be, but shouldn’t the new Z-Wave firmware and a Heal fix the network?
Advice please?
