Is this a known problem? I’ve tried firmware 1.1229 and 1.1234 both added from factory default reset and then enabling z wave version 3.20, but whenever I click the z wave learn button it fails (viewable in MIOS webpage) stating is was unable to enter the learning state.
I’ve had to go back to the older version in order to add my devices again :O(
After adding a few devices it started to fail to go into learn mode repeatedly.
Nodes #'s were being dropped and it was taking numerous attempts to add each device.
After adding about 12 devices I gave up and reverted back to 2.78 and used my Aeon dongle and added devices the old fashioned way, 10 at a time with no issues.
Not good, I don’t want to go through the setup process again if it’s just going to fail again, I think I’ll wait for the other ‘beta testers’ out there to get it working before I start again. I don’t minf setting up the scenes etc, that’s quite fun, adding devices when it doesn’t work and going back to square one is not so much fun.
I also am unable to add devices after I flashed my Vera2 to 1.1.1234 / 3.20. I have two devices (ZIR010 motion detector and Aeon door sensor). See also the thread I started yesterday about this.
How can I check if the Vera2 entered learning mode? I am able to log in to the box with ssh if needed.
the z wave LED on the front panel will flash slowly on and off.
With mine it will flash slowly for a short while then go back to steady on, if I have a browser connected I can see a message in the top right that says “z wave failed to enter learning mode”.
Incidentally, it doesn’t seem to fail when you enter the exclusion mode, that bit works ok (press and hold z wave button for about five seconds), then if you try the include button on a device the browser message is successful.
Don’t know why this is and I’m not currently willing to reset everything and try again and rest the z wave after clicking the “use 3.20” checkobx, although I think I did this already.
Fixed it. Indeed, I had to first exclude the devices, as wscannell suggested in the thread I started about this ([url=http://forum.mios.com/index.php?topic=6154.0]http://forum.mios.com/index.php?topic=6154.0[/url]). Will post more details in that thread.
