[quote=“rlmalisz, post:11, topic:166492”][quote=“rlmalisz, post:10, topic:166492”][quote=“shady, post:9, topic:166492”][quote=“EE, post:1, topic:166492”]Hi All,
I finally got my Vera 2 and trying to connect the Foscam FI8908W i have, but it fails. If I miss something please let me know:
- I changed the Foscam UID to cdceadmin and password to dcepass. - no problem with the camera access and control from the PC.
- connected the Vera2 and got it working
- selected devices, and uploaded to vera the I_PanasonicPTZ.xml created by Shady, (see attached)
- Created the device and saved it.
- Vera will not discover the camera, (specified at the same IP Address as I can access it from my computer, and the respective MAC address)
I would appreciate if someone can create a complete list of steps to go through to configure the FI8908 cam from beginning to the point you can view it and control it. Somehow I got confused by the different pieces of advice I could find at this forum.
Thank you for your help.
Thank you for your cooperation[/quote]
Did you make sure to install the Panasonic Plug-In from Mios Marketplace before uploading the file that I posted? If you install the Panasonic PTZ plug-in after uploading the file I posted or not at all, then it won’t work.
Then make all of the changes to the Camera device, for User/pass and URL[/quote]
So I received a Foscam FI8918W today. Have it working on my WiFi–went ahead and gave it a fixed IP, as that’s my preference for things that aren’t going to come and go. Access works fine. Set up a user as “operator” with the MCV recommended name and pw. Am ready to hurt myself by setting up my Vera1 (1.0.988) to access it. The discussion above speaks of the MIOS marketplace, but may be Vera2-specific. Where should I be getting the files for the Pannie PTZ and Shady’s mods for Vera1, UI2?
I know–I should move on. I have a Vera2 sitting on my desk. I am waiting for the software for UI4 and V2 to get more stable. I’m away from home enough that I can’t have the home automation getting twitchy on me!
Thanks in advance…
–Richard[/quote]
So in UI2, under Luup plugins, there’s a “generic PTZ camera plugin”. Is that what I should be using?
–Richard[/quote]
So if I go look at the Luup Gallery in a browser, I see the PTZ Panasonic. Using UI2, when I go to “install LUUP plugins”, I can only access the first page of plugins–clicking on the link for the second page fails both if I am logged in locally, or through ra1.findvera.com. Locally, it fails silenty–I just get a blank page. “Remotely”, I get: “The requested URL /cgi-bin/cmh/proxy.sh was not found on this server.”. It looks like there was a complaint about this some time back. I am running 1.0.988. What version of UI2 is the latest/greatest/actually-works?
Or is there some other way I can get to the files for this Panasonic PTZ?
Sigh.
–Richard
